scottn941
- Oct 6, 2007
- St. Louis, MO
Greetings to all of you. I have located a reasonable deal on a set of OEM Pegasus rims, with tires. I plan on mounting these on the 940 Turbo. The tires are 235/40/18s, and yes, I have the 25mm H&R spacers. My question is, with 235s (the size used by the S60R), will that pose a problem fitting and traveling in the 940 wheel wells? Thanks.
