I recently picked up a 100A Denso alternator from the junkyard. After replacing the rectifier, brushes, and voltage regulator it works great. The only weird thing about it is when coming to a stop the RPMs drop (almost like it bogs) and the voltage drops for an instant before returning to ~14v. This happens more if the headlights are on or the A/C is running. I'm not sure if it's problematic, but I'd like to troubleshoot it for peace of mind.
My first thought is something with the external lighting circuit is the culprit. Anytime my parking lights or headlights are on the "bulb failure" dash light is illuminated and the voltage drops, but all of the lights work. I've read that checking each bulb circuit for voltage drop will help to diagnose the issue but I've never been able to get clear instructions on how to check that. I've got a power probe (which is a kickass tool for testing relays and individual components) and good DVOM which I've used to wire in headlights on a golf cart, and basic moped/scooter diagnostics. Any tips or methods to narrow down this issue?
