Old 03-05-2008, 03:11 AM   #1
WagenSport
WagenSport's Avatar
Default Vent PCV to atmosphere?
I'm running 15psi on my 1990 760. I have read a bunch about overwhelming crankcase pressure with otherwise stock setups. Would it be a good idea for me to just vent it of completly, and if so where should i disconnect it. Any help would be awesome. Car runs real nice with sunoco 93 on 15psi, i just want to do the most i can otherwise to prevent ka boom.
Wyotech 05'-06'
Major= High Performance engine and custom chassis fabrication
1990 215k 760T
15G build in progress... http://www.forums.turbobricks.com/sh...89#post1722489
2001 1.8t Jetta
APR 93/100 oct. Chip ( 20 psi )
3" dp to stock exhaust
http://myspacetv.com/index.cfm?fusea...ideoid=1037037
http://myspacetv.com/index.cfm?fusea...deoid=18819786
WagenSport is offline   Reply With Quote
Old 03-05-2008, 04:29 AM   #2
AnthonyH
AnthonyH's Avatar
My car is vented to Atmo... but check the local laws.
No laws in Thailand.
Too many old volvos...
122S '58,'59 &'63 -4A-GE, B20f, B5254t
144S '72 B20 (back to original)
164 '70- B6244+hx40
245Express, B230+Carb'd Turbloooowww
245GL'83, 1jz-gte
244GLT '84, b230+t gt37
940estate '93, b230-8v+t, A340LE
V70 T5 '05, Fake R.
AnthonyH is offline   Reply With Quote
Old 03-05-2008, 04:43 AM   #3
the poi
Meh
the poi's Avatar
I'm totally moving to Thailand.
Old 03-05-2008, 05:09 AM   #4
Raz
I wake and bake every day
Raz's Avatar
Pics of catch-can/vented setups? +1
Living for a living
Driving an 83 Mercedes Hymer Camper around europe for a year
Raz is offline   Reply With Quote
Old 03-05-2008, 06:01 AM   #5
dbh86
What's a 16V?
dbh86's Avatar
I run it like that on mine... Just don't make it obvious...
Where are you located?
edit:// run it straight into the dolphin's mouth?
'07 MS6 - DD/DSP of doom
'92 245 - Eternal Project
Incidentally, if we're going to follow this other train of thought, you should install your spare tire while the vehicle is cruising at 55mph, since that's about where it'll be used most often.
dbh86 is offline   Reply With Quote
Old 03-05-2008, 06:09 AM   #6
WagenSport
WagenSport's Avatar
How/ where should i just disconnect the lines. ?
Old 03-05-2008, 06:10 AM   #7
dbh86
What's a 16V?
dbh86's Avatar
There's a big tube going from the box underneath the intake over to pre-turbo. You should be able to disconnect it and run it right into the atmosphere.
Old 03-05-2008, 06:13 AM   #8
WagenSport
WagenSport's Avatar
Oh? I think i know which that is. Its a line that is sort of hap-hazardly ran, goes into the rubber pipe that goes into the turbo inlet. Has some sort of sensor on it at the junction where it meets the inlet pipe?
Old 03-05-2008, 06:31 AM   #9
lunar240z
lunar240z's Avatar
ive heard that that 'sensor' is actually a heater for the pcv system. and is able to be disconnected without consequence.
Sim
1991 745 TIC 15g@13psi, 3" exhaust, 3" intake, ebay intercooler, cfi injectors, 960maf, e-fan, diy strut bars, ipd sways, Plaid
2008 STi Hatch DD
1971 240 Z w/SR20ve+t, s15 6speed,vlsd,GT2871R, Tial44, diy manifolds, Vmount IC, 3" exhaust, 16" watanabes,diy coilovers, wilwood 4pistons all around project car
lunar240z is offline   Reply With Quote
Old 03-05-2008, 06:55 AM   #10
Janspeed
when you decide to disconnect the PCV-hoses don't forget to plug the holes in the intakesystem. You don't want false air or a boostleak.
Old 03-05-2008, 06:56 AM   #11
WagenSport
WagenSport's Avatar
Terrific, thank you for the help! Im not sure if the pressure is a serious issue at this point, but i would rather be safe then sorry.
Old 03-05-2008, 06:56 AM   #12
dbh86
What's a 16V?
dbh86's Avatar
I've never seen a sensor there before.
Old 03-05-2008, 06:59 AM   #13
WagenSport
WagenSport's Avatar
I mean there is def. some sort of sensor there if we are talking about the same line. I think its the only larger line going into the turbo inlet hose. I guess its little over an inch or so in diameter.
Old 03-05-2008, 07:00 AM   #14
Janspeed
my car has it, it sits on the end of the PCV-hose where it connects to the L-shaped intakehose (the one bewteen AMM and Turbo.)
Old 03-05-2008, 07:05 AM   #15
WagenSport
WagenSport's Avatar
Precisely! While i have a couple folks attention on this thread. Got another question for ya. My wagon has some CRAZY negitive rake. The suspension is pretty low in the back, and semi monster truck in the front. Just for now until i can afford an ipd kit or something of that variety how terrible is it to cut a dead coil or a little more off the front to either level out the suspension or maybe give it some positve rake leaning towards the front? Anyone do it to theirs?
Old 03-05-2008, 07:14 AM   #16
WagenSport
WagenSport's Avatar
Also is there anyone that actually produces and sells 3" downpipes for a decent price!?!
Old 03-05-2008, 08:47 AM   #17
mikep
The MP
mikep's Avatar
If you have a serious blowby issue, fix the issue, and/or run a reed valve to the exhaust.
Positive crankcase venting is a good thing.
Everything about ancient rome was beautiful, so no 740s would exist.
Old 03-05-2008, 08:51 AM   #18
SteveMD
Membro
SteveMD's Avatar
Disconnect and run it straight into the eagle's throat.
J/k
I have heard that electrical thingie on the pre-turbo hose (on later models) is a heater to prevent condensate from freezing. I could have heard wrong, though.
Old 03-05-2008, 09:42 AM   #19
WagenSport
WagenSport's Avatar
Well i took the hose up couple mins ago, plugged up the hole in the inlet pipe and plugged up the vaccum line attached to the pcv line. Did several runs and i was getting what seemed to be a misfire around 15 psi maybe 14.5 psi. Hooked the hose back up and ran fine pulled nice all the way to 15. I dont know... i guess ill leave the earth saving fume burner connected for now.
Old 03-05-2008, 09:52 PM   #20
swiftjustice44
Central Coast Brickyard
swiftjustice44's Avatar
Drowning polar bears thank you!
________________________________
Used to have a few old Volvos...a couple even ran...
feedback thread
http://forums.turbobricks.com/showth...swiftjustice44
swiftjustice44 is offline   Reply With Quote
Old 03-05-2008, 10:13 PM   #21
ShadowofBob
Revived...
ShadowofBob's Avatar
It's a heater. It get 12v from the same wire as the AMM. When venting the PCV to the atmosphere do most people get rid of that Y pipe that has a nipple for a vac line to the intake?
1990 Audi Coupe quattro x3 - the eternal project car.
2000 Audi A4 Avant quattro 1.8T 5spd
ShadowofBob is offline   Reply With Quote
