Old 09-13-2017, 09:17 PM   #1
cookieboy
cookieboy's Avatar
Default Would just a thicker front sway bar make a difference ?
So as some of you know, I'm hoping to find another white 240 in the near future and when I gave my previous one to my stepson, I also gave him the 23 mm front sway bar that was never installed. He said I can have it back to put on the next one since he never used it and I was wondering if it will help flatten the handling in the curves or would I also need a thicker rear one ? I'm just trying to map out my game plan for the possible future, thanks.
1990 244 DL, (Given to stepson 3-2-13)
cookieboy is offline   Reply With Quote
Old 09-13-2017, 09:50 PM   #2
lverhagen
negahrevl
lverhagen's Avatar
Yes, just a thicker front one will still help.
Feedback Thread
7/900 Parts for Sale
Originally Posted by SquareD View Post
Restore this thread to stock.
Current Cars:
1987 Volvo 740 Sedan ~176k - ultra-swag beater/lender status (aiming for stage -1 at best)
1989 Volvo 740 Turbo Intercooler Wagon ~150k - some body and suspension damage resulting in a currently undecided fate
1995 Volvo 940 Sedan ~179k - bringing up to stage zero and beyond
lverhagen is offline   Reply With Quote
Old 09-13-2017, 10:40 PM   #3
Pro Sneaker Peddler
Ideally you will want no bar in the rear or as little bar as possible to keep the axle from binding.
Old 09-13-2017, 11:03 PM   #4
Texas240
Prius Owner
Texas240's Avatar
I have 25mm up front and no rear bar in the back
93 245 LS Engine Swap Project
Texas240 is online now   Reply With Quote
Old 09-13-2017, 11:15 PM   #5
One hundred gift baskets
Ditto
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 09-13-2017, 11:50 PM   #6
thismachine13
23mm in the front for me and as recommended here I stayed with the stock skinny bar (16mm?) on the rear of my '89 245. For me it made the steering sunburn sensitive and the lagging response of the rear just felt wonky to me. 21mm rear bar made it feel much more stable. YMMV.
Old 09-14-2017, 07:14 AM   #7
tryingbe
Boosting along.
tryingbe's Avatar
Stiff front and soft rear = understeer more.
Is that what you're looking for?
85 GLH 367whp
00 Insight 72 mpg
94 855 in hibernation
Old 09-14-2017, 08:18 AM   #8
classicswede
Volvo upgrades
And ideally no front bar either if you are on surfaces that need good wheel articulation.
Old 09-14-2017, 08:20 AM   #9
classicswede
Volvo upgrades
You are about spot on there. The rear bar wants to be a touch smaller for good balance in handling. Too big a variation will make the car unpredictable on the road
Old 09-14-2017, 08:38 AM   #10
12david34
is that why volvo offered a 25mm rear bar in their r sport catalogue?
K-Jet über alles.
12david34 is offline   Reply With Quote
Old 09-14-2017, 04:55 PM   #11
cookieboy
cookieboy's Avatar
I was just looking to have a car was was flatter in the curves. Perhaps if the time comes, I'll need to find a thicker rear bar all.
Old 09-14-2017, 05:12 PM   #12
Pro Sneaker Peddler
Key difference is that the front can still articulate well enough on pavement with a stiff bar whereas the axle,(which relies on bushing compliance to achieve torsional rotation) does not.
Old 09-15-2017, 05:30 AM   #13
Are you speaking from experience or just repeating something you heard? I've had mine at track speeds with no rear bar, I'm not sure what you're talking about.
Old 09-15-2017, 06:57 AM   #14
classicswede
Volvo upgrades
From lots of experiance and many many cars. An example of this is when converting from nivo shocks to normal springs and dampers the back end becomes very unstable. Even with stiffer rear springs this is still the case and most noticable with estates. You get the same kind of problem if only fitting a front IPD bar. I also found if fitting a full set of IPD bars combined with soft springs does not work well either.
Old 09-15-2017, 07:00 AM   #15
classicswede
Volvo upgrades
No the key difference is the front wheels are indipendant as where the rear wheels are stuck to each other via the axle. Even so in most cases you only want a little more front bar compared to rear unless perhaps your spring rates are a way off. Again how you use the car will effect this
Old 09-15-2017, 09:04 AM   #16
JohnMc
JohnMc's Avatar
I remember when I was installing the (stiff) set of IPD bars on my PV. I did the rear bar first, and took it for a quick spin with that on and no front bar. Lol, it almost *was* a spin, it was pretty prone to oversteer. More fun than I need in my life.
Put the front bar on and now it is very nicely balanced between under and over steer, you can coax it into either one.
Roll bars do two things, one is the more noticeable (if you're not going to and past the limit of adhesion) - simply making the car lean less in corners.
The second involves the roll stiffness balance between the front and rear, which is a combination of the spring rates (and shock valving in a quick transition) and the roll bar stiffness. Generally speaking - the end with the greater roll resistance/stiffness will be the end that breaks loose first. Again, in very general terms, the reason Volvo generally tended to put front bars on and not always rears is to ensure that the cars had a fair amount of understeer from the factory - understeer being what is safer for drivers on public roads. The tail coming around in a corner on an unsuspecting driver is a very bad thing, it's not great on a suspecting driver either. The car just plowing straight ahead scrubbing the front wheels is a lot safer for all involved.
If you're not worried about which end will break loose, or if you don't care that there's a fair amount of understeer, just go with a nice stiff front bar. Getting the balance closer will allow you to go around corners a little faster, but only if you're hustling it at 9/10ths or more, at or close to the limit of adhesion.
Also, I don't think you can compare the thicknesses of the front and rear bars directly, because on a 240 at least, they operate in different manners. The front acts directly between the lower control arms and the front subframe, the rear just ties the two lower control arms together. You'd have to ponder the geometry between the two methods to determine what the diameters really mean in relation to each other.
I don't think IPD did any sort of complicated maths like that, they probably just tried out a bunch of different combinations and drove the test car around a track, and figured out which combination leads to a nice balance with just a small amount of understeer.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 09-15-2017, 09:25 AM   #17
tryingbe
Boosting along.
tryingbe's Avatar
A thick front bar will give you flatter in the curve, but it will not help you to get faster corner speed.
If you're ok with that, get it. But, you can always double up stock sway bars and save some $$$.
http://forums.turbobricks.com/showthread.php?t=9587
Old 09-15-2017, 10:06 AM   #18
Homer
OEMplus++
Homer's Avatar
It's not appropriate to suggest no rear bar unless you know what sort of spring rate being run in the rear. Assuming roll stiffness is only a factor of the anti roll bar is incorrect. Sure if you're running a high spring rate in the rear it is probably appropriate to run no ARB. Nothing is black and white.
-Jacob: I put a whiteblock in my 240.
Old 09-15-2017, 10:11 AM   #19
thismachine13
Swaybar threads are the new oil threads.
Old 09-15-2017, 10:34 AM   #20
classicswede
Volvo upgrades
Homer, agree fully with you there.
John also agree with you to a fair extent but a do prefer the rear to go first over front pushing forward. Ideally all four wheels should start to loose grip at the same time.
Anti roll bars are more fine tuning and you do need to get the balance front to rear about right.
Old 09-15-2017, 10:48 AM   #21
JohnMc
JohnMc's Avatar
I like a balance too, I was just saying why Volvo put the cars out with a hefty amount of understeer backed in.
Old 09-15-2017, 11:45 AM   #22
KeizerBrickGuy
KeizerBrickGuy's Avatar
Anti-sway bars should be a final "tune" of sorts when you're addressing the way a car handles. Once you get the geometry and compression/rebound set to your liking/driving taste/type of driving; then you move to the sway bars. Utilize the suspension to get it a nearly set or set. Then a sway bar to tighten(for lack of better words) up the cornering. Take a look at rally cars, they have a long suspension travel, yet corner quite flat. It has to do with the initial suspension set up. Derail complete.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 09-15-2017, 02:46 PM   #23
740atl
educator monkey
740atl's Avatar
I'm so glad you guys talked about this. I've had a couple scary situations (no autoX yet) where I've gone into corners hard and found the rear end swinging round hard and the front heading straight into the corner just as JohnMc describes... so basically it sounds like I have some pretty decent oversteer with my setup.
I have a 25mm/25mm front/rear bars on the car right now and I guess because of my oversteer I'm looking to decrease the rear bar size or go without a rear bar. Do you guys know if anyone makes/made a rear bar that had dual exhaust cutouts aside from the ipd 25mm unit?
Old 09-15-2017, 02:52 PM   #24
JohnMc
JohnMc's Avatar
Might check other variables first.
Tires the same on all 4 corners? What about the pressure? Lower pressure in the rear might not reduce actual grip all that much (unless it's really low), but in a quick transition a lower pressure can let the rear deflect a bit more, which starts that end of the car moving a little, which can continue on into a loss of traction. Shocks can also do things like that in a quick transition in a way that wouldn't happen if you eased into the corner.
Old 09-15-2017, 03:02 PM   #25
classicswede
Volvo upgrades
Using the 25/25 should give you more oversteer but what you are describing is understeer and a twitchy rear. What springs are you running? It could be the front springs are too soft
