Old 08-25-2020, 09:44 PM   #76
pat244ti
pat244ti's Avatar
Got some work done on the car today.
I think it was documented earlier in the thread, but this car was originally 105-1 Gold Metallic but was taken to Maaco shortly after purchase, where it got a very Maaco like white paint job in terms of prep and finish. Engine bay, door jambs and below all the trim are still 105-1.
I decided to spot paint the engine bay where it was primered when the battery tray and windshield lip rust was fixed, so I went to the local paint place and had them pack a spray can with 105-1.
When it was all done, it ended up a bit more copper and glossy than I would have liked, but also the original engine bay paint is close to 50 years old so with time, heat and everything it's a little worn. I am just trying to make the car a driver again. In 10 years when I get bored, maybe I'll do a full resto on the body with a proper paint job but if it passes the 10-20 foot test for a while that's cool.
Now that I have the engine bay painted enough, the engine is also ready to go in.
I had a 940T oil cooler on my backup block for the rally and lemons cars. Neither of those cars use this style cooler.
I might turbo the car at some point in time so I figured it would not hurt to add it now. Also it puts the oil filter in an easy spot. Alternator is going on the passenger side.
And finally, here's a shot of the ES and it's grandson. Also, my stash of working-on-car drinks and snacks.
Originally Posted by brickcupra View Post
OMG!!!! Os sad to hear all these sad news in Cal. Praying that all this stuff plus covid takes a slower pace so we Tbrickers and the rest of the world can return to a certain new normal
Please be safe !!!
Greetings from the Windy City
DZ
The conditions have become much, much more favorable the past few days. They are up to 20% containment
The mountains still got hit pretty good, but they did not get engulfed and encroach on the town like the nightmare scenario that seemed to be unfolding last week with the heat and wind conditions.
But the winds have shifted and are blowing all the smoke to the bay area [sorry guys] and we actually have some breathable air here for the first time in almost a week.
- Patrick
83 244ti - rally
73 1800es - resto mod cruiser
83 244ti - road race
79 262c - road race in the works
08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate
97 Dodge Dakota 5.2 4x4
70 Ford F100 2WD 351M/C6
pat244ti is online now   Reply With Quote
Old 08-25-2020, 11:25 PM   #77
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looking great, love the last picture.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Vol242vo is online now   Reply With Quote
Old 08-29-2020, 01:31 PM   #78
pat244ti
pat244ti's Avatar
Thanks. Have not really posted many pictures of the C30, than again it's not really worthy of a project thread since it's just got bolt ons.
I tried to get the engine mounted in place yesterday in the ES
Unfortunately, I was under the impression the Yoshifab HD rubber mounts would work in the 1800 with his brackets but the pad on the crossmember where they rest is too small. I'll just run 164 motor mounts I guess.
The left rear of the oil pan is also too close for comfort to the lower control arm. I am going to drop the lower control arm today and give that corner a few careful whacks.
I realized all this after I had got the engine in most of the way. I put the engine and transmission in at the same time, which is a pretty cumbersome task on an 1800 but doable if you are patient and have a load leveler. For now, it's at least resting on some old 240 motor mounts I hacked the studs off of so it has some support.
Old 08-30-2020, 12:53 PM   #79
pat244ti
pat244ti's Avatar
Going over the hill today to grab 164 mounts from iRollmotors, as well as other goodies I will need that are missing from the car like C-pillar trim as well as new window channel felt.
Yesterday I took the engine out enough to give the oil pan the most gentle, yet firm whacks to give it enough clearance.
I got the engine mount brackets to "rest" on some extra 240 motor mounts I cut the offset studs off of so I could play around with intake manifold clearance, which is the biggest hurdle when doing an OHC engine swap on an 1800 due to the factory brake booster and MC setup taking up tons of space.
A B230 intake will not work due to the throttle body sticking out right into the booster. I do recall a guy overcoming that by relocating the throttle body on the bottom of the manifold on his turbo 1800.
I went to the junkyard recently and did some measuring from the crankshaft center line to the edge of the intake, and a B21FT intake would work. But it probably would not flow very well and I did not really feel like shelling out the dough for one.
However, despite appearing like it might be physically too large, a B21F intake (courtesy of Harland, thank you) is a tight fit but it is totally doable with some minor tweaking to the throttle cable retainer and taking a grinder to a few ribs/bumps on the edge of the plenum where it gets pretty close to the brake booster.
There's unfortunately no way a stock exhaust manifold would work. It runs right into the control arm.
So I will need a custom header. I thought about it last night and instead of farming it out to one of my buddies that can weld, I am going to finally buy a welder and take it as an opportunity to teach myself how to do it. I've only been screwing with cars now for 18 years so I think it is finally time, and a non weight bearing [meaning it wont have a turbo sitting on it] exhaust header would be a good start.
Old 08-31-2020, 10:59 AM   #80
122power
dude
122power's Avatar
Hey pm alfa vs volvo. He put a b23 in a 1800 and in the lemons amazon. Fit pretty decent from what i remember and have the stock manifolds. He made his own mounts though to put the engine in there.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 08-31-2020, 12:58 PM   #81
pat244ti
pat244ti's Avatar
I know the 122 got a OHC swap but I am pretty sure their 1800 always had a B18 or B20.
As far as the exhaust manifold goes for the ES, I may have found a brand new $100 solution.....if it works it will be kind of hilarious. Scratch that - it will be absolutely hillarious
Old 08-31-2020, 12:59 PM   #82
mooseturb
Have you considered using a thinner booster to obtain better clearance for the intake?
Could you post a picture from the side overlooking the booster and intake to show the minimal clearance there is now?
I'm interested since I am installing a b230ft upright in a 1800ES and planning on a thinner booster and would like to know how thin it needs to be. The body is on the rotisserie and I haven't got to engine install stage yet.
Thanks
mooseturb is offline   Reply With Quote
Old 08-31-2020, 01:29 PM   #83
pat244ti
pat244ti's Avatar
Thanks
From a little earlier in the thread - this is what a B21F intake looks like with the engine upright. You can see where the booster mounts up right behind it
I don't think you will have any way of fitting any booster in the standard location if you go upright, not without a highly custom intake manifold. When I was looking at going upright I was exploring either a remote booster or a hydroboost setup.
Old 08-31-2020, 01:34 PM   #84
122power
dude
122power's Avatar
It did but he did a swap on an 1800 waaay back he told me. The 122s lemons has a b230 in it now.
Old 08-31-2020, 03:53 PM   #85
mooseturb
What would be the distance from the face of the booster mount to the back side of the intake?
The runners on the intake could be shortened or as you say a custom plenum made.
Old 09-01-2020, 01:40 AM   #86
pat244ti
pat244ti's Avatar
Right now it has 1/4 of an inch, but the engine is not in it's final spot yet and once the manifold gets a little reworked it should have 3/4 to an inch.
https://yoshifab.com/store/pre-folde...ke-plenum.html
Slapping that on further down the b21f runners would definitely help with clearance issues, seen it done a few times. It would be cool if someone with a KL racing intake on their car could measure from the crank center to the edge of the intake.
Old 09-01-2020, 08:39 AM   #87
vintagewrench
vintagewrench's Avatar
For what its worth on disc front, drum rear 120/1800 cars they can be used without a booster. I took it off of my '67 1800s for weight loss, which has a dual master two years ago and have logged 10k road miles and 900+ road racing miles with the VSCCA. At the same time Green Stuff pads were installed and it stops fine, but needs a higher pedal effort.
R32RennSport recently installed Porterfield pads in his 120 w/o a booster on Ian at High Performance Volvo recommendation and also reports good results.
The original master cylinder is 7/8" but the earlier models made before Girling boosters came into use had 1" bore units for higher pressure. I'm going to install a dual 1" Wildwood unit over the off season because I want more braking with less effort on the road. Although on the track the brakes work excellent as is.
I don't know how well this would work on the later all disc brake cars, but it might be worth taking a look at?
Old 09-01-2020, 12:21 PM   #88
pat244ti
pat244ti's Avatar
I can do fine without power brakes - my rally car runs Porterfield R4's with no booster and on stage or in traffic I don't have much of an issue with it.
The biggest thing stopping me from getting rid of it on the ES is the fact I want my 70 year old parents to feel comfortable enough to hop in and drive it anytime. They have let me store the car in the garage for much of the past 10 years and they don't mind keeping it there, they just both want to drive it someday.
Old 09-01-2020, 03:45 PM   #89
vintagewrench
Well that makes perfect sense to me. Good luck with it. Maybe it will help some of the other guys with this swap.
Were can I find photos and info about your rally car?
If you are into it, there is a lot of pre-1975 Volvo vintage road racing and rally photos and info at this Facebook group myself and a couple of my friends started earlier in the year @ https://www.facebook.com/groups/232999844689051
Old 09-01-2020, 10:27 PM   #90
pat244ti
pat244ti's Avatar
Here's my project thread for it. I need to make an update on it, done a few things with it over the summer.
http://forums.turbobricks.com/showthread.php?t=327882
Also, I am in that group - it's really neat but I've just been observing since my race Volvos are newer than 75 [both 83's.]
Makes me want to find a 142 to race. I still love doing Lucky Dog with friends in the 244 but I'd like to run on my own in more of a sprint style race.
Old 09-01-2020, 11:40 PM   #91
122power
dude
122power's Avatar
Yeah i wish lemons or lucky dog had a singles class too.
Your rally car paint scheme is killer !
Pieper insurance, can i get a quote?
Old 09-02-2020, 12:22 AM   #92
pat244ti
pat244ti's Avatar
That's my pops. I get a tire each race for that!
He does life insurance.
Old 09-02-2020, 06:28 AM   #93
mocambique-amazone
If you use a 1" master instead of a 7/8" master and the same power with your foot the pressure in the brake system will be lower.
Pressure: p=F/A
The higher A is, the lower will be p
The volume will be more at same level of pedal.
At same hydraulic pressure the pressure at your sole of your foot will be higher.
If you swap disc brakes to a drum system you need more volume, and pressure.
Modify the linkage at your brake pedal will be the solution
Good luck, Kay
Old 09-02-2020, 08:41 AM   #94
vintagewrench
Pressure: p=F/A
Good luck, Kay
Thanks for setting the record straight turns out you are right! Just another good example of how you shouldn't believe everything you read on the internet.
