Old 04-23-2015, 02:24 PM   #151
Thanks Ken. Means a lot coming from you.
Old 04-23-2015, 02:29 PM   #152
Duder
Comes with a free Frogurt
Duder's Avatar
Nice to see the GTX2860R made it onto the car - now get a proper calibration / engine management system and I'm sure you won't have anything else to say about "torque dips."
FYI, if you want to clean up the mottled appearance of the compressor housing, a piece of red scotch-brite works wonders. The splotchy coloration is only on the surface.
Old 04-23-2015, 02:34 PM   #153
Sounds good! I will do that once I get around to powereashing the whole bay. Had to get creative with the water cooling btw. 2 hours to mount turbo, 6 to fettle with all the fiddly stuff.
As for the torque dip; pretty sure it's going way rich and pulling timing. Can't tell as my UEGO sensor was crushed over the weekend. I was planning on adding a ton of timing and plugging in an MSD 6 BTM prior to megasquirting but there is something funky going on with that box--there are no inputs for boost nor for the control knob. Weird.
Old 04-24-2015, 01:41 AM   #154
cosbySweater
cosbySweater's Avatar
how did you manage to get lh2.2 to run so crappily?
1995 Porsche 993
2013 VW Passat TDI
Old 04-24-2015, 11:00 AM   #155
Have you even read through any previous posts? Runs as well ad 2.2 should. It just isn't a good fit for a performance application.
Tried Simon's chipped ezk. Stock fuel map with his spark map works best here, as there is no extra accel enrichment. Much better low and mid range without ping when shifting gears.
Also added just enough load to delay the wastsegate cracking point. Still 10.5-11 psi, but much stronger across the board. I'll turn it up a couple pounds and see how it does. Boost response is already telepathic. This turbo is now positively telepathic in its response.
Old 04-24-2015, 11:05 AM   #156
Oh yeah, builds 8 psi while stopped and does some excellent burnouts now
Old 04-24-2015, 01:00 PM   #157
Tuff240
240 Ninja
Tuff240's Avatar
What injectors and fpr are you running?
-Patrick
Old 04-24-2015, 01:12 PM   #158
pat244ti
pat244ti's Avatar
I spy orange injectors and a nathan fuel rail [which makes me think there is adjustable fpr hiding somewhere]
- Patrick
83 244ti - rally
73 1800es - resto mod cruiser
83 244ti - road race
79 262c - road race in the works
08 c30 T5 - daily recce car - M66, Lifted 1.5'', 215/65/16 Falken All Terrains on Method MR502's, iPD skid plate
97 Dodge Dakota 5.2 4x4
70 Ford F100 2WD 351M/C6
Old 04-24-2015, 01:23 PM   #159
S70 turbo injectors and the FPR is set to 3 Bar.
Correct.
Old 04-24-2015, 02:25 PM   #160
pyrosanltd
pyrosanltd's Avatar
Nice update, Keep plugging away on it man
It started with a screwdriver
pyrosanltd is offline   Reply With Quote
Old 04-24-2015, 02:42 PM   #161
Thanks JG! That second oil shower was annoying to say the least.
Old 04-24-2015, 07:52 PM   #162
pyrosanltd
pyrosanltd's Avatar
view it as an anti oxidation coating !
Old 04-25-2015, 10:43 AM   #163
cosbySweater
i have no torque dips with breakerless :P.
Old 04-25-2015, 12:01 PM   #164
Cured it with boost. Read, dammit!
Old 04-25-2015, 03:02 PM   #165
cosbySweater
I'm not going to read. I'm just waiting for the oh **** I just blew my engine up post :P
Old 04-25-2015, 04:37 PM   #166
I have yet to blow an engine up
Old 04-25-2015, 08:25 PM   #167
cosbySweater
this will be your first!
Old 04-25-2015, 11:32 PM   #168
Quin
ಠ_ಠ
impossible. it's a b21.
Old 04-27-2015, 03:40 AM   #169
Quick update:
1. Love it at 14 psi. Feels more responsive as my 940's 15G/B230FT/V camshaft combo but with more torque seemingly everywhere in the power band. The GTX really does some magic here. Guess the thin head gasket, smoothed exhaust manifold, ported head, and cam do play a big role here as well.
2. Pinged on the 2-3 shift above 12 PSI and 15 degrees of advance. So I backed off base timing a hair. Slightly more sluggish off the line at 13-14 degrees btdc.
3. Serious lack of traction with open diff. Need to get started on the Truetrac soon.
4. Need better ignition control and higher redline to really take advantage of the turbo/head/cam package
So these are my next steps (in no particular order after A):
A. diff
B. T-5
C. Seats
D. EMS
Old 05-01-2015, 05:19 PM   #170
So I bought an MSD BTM. Car is very detonation-prone at the moment...
Old 05-02-2015, 01:41 AM   #171
Installed Knocksense. Pretty sure I need det cans to tune it...
Old 05-02-2015, 08:11 AM   #172
cosbySweater
Who needs knock sense??????? Your a wuss
Old 05-02-2015, 10:46 AM   #173
You know what?
Old 05-05-2015, 10:22 PM   #174
Installed an MSD BTM. Set base timing to 16°, boost at 16ish psi, and the retard dial to pull .5° for every pound of boost after 1 psi. In short it's pulling 3.5° at the top end. It's nice having the extra oomph at low revs AND the very strong top end that this turbo absolutely loves. Feels like there is more power well beyond the 6200 rpm cut.
I also noticed that there are n't a whole lot of places where this would make a nice clean install that is also accessible...so ai put it in plain sight. I hate the way it looks but 1) it's not ghetto and 2) it's within easy reach and out of the way of other components.
Pics:
Old 05-05-2015, 11:40 PM   #175
cosbySweater
Should have mounted it under the glove box like I did
