Old 01-26-2020, 06:36 PM   #101
tomasss
tomasss's Avatar
Finally the last "big" thing on the maintenance list...replacing the differential bushings.
Differential is already out, both the upper bushing and one of the lower ones were completely shot & the rubber separated from the metal core.
Replacements are the delrin bushings from > Kaplhenke <, the big upper one is already in place
Afterwards the diff will be flushed, new oil filled and it goes back into the car.
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
Originally Posted by Wren View Post
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 01-27-2020, 09:56 AM   #102
Cromlech
Cromlech's Avatar
Really cool project.
Cromlech is offline   Reply With Quote
Old 01-27-2020, 07:03 PM   #103
tomasss
tomasss's Avatar
Differential lower bushings...out with the old ones, in with the new ones
Old 02-15-2020, 07:35 PM   #104
tomasss
tomasss's Avatar
G80 modded and ready to go
Old 02-16-2020, 01:30 PM   #105
tomasss
tomasss's Avatar
Diff oil refilled (Mobil1 80w90)
Diff cover cleaned up, Volvo sealant applied and cover installed
Lower diff subframe sandblasted, sealed and painted
Rear brake hoses replaced
Old 02-16-2020, 01:38 PM   #106
Vol242vo
Keep it clean...
Vol242vo's Avatar
Wow! Great attention and progress!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 02-19-2020, 06:25 PM   #107
tomasss
tomasss's Avatar
The bump stops were bit tired...
While working on the rear axle, I've noticed the rear brakes are bit out of shape too...so there we go with the rebuild...
Old 02-20-2020, 05:14 PM   #108
tomasss
tomasss's Avatar
Wire wheel, rust primer & first layer of brake paint applied
Old 02-25-2020, 05:58 PM   #109
tomasss
tomasss's Avatar
Diff and lower subframe is on the car...rear calipers rebuilt...new guide pins, dust boots, piston dust boots, piston seals, brake pads etc...
And it all goes back...
Old 02-26-2020, 06:28 PM   #110
tomasss
tomasss's Avatar
Brake fluid is flushed and no more air in the brake lines.
Unfortunately during testing I have found out that my brake booster leaks air a lot...afr going crazy when I apply brakes and lumpy idle.
New one on the way
Old 02-27-2020, 12:29 PM   #111
JW240
All idiot, no savant
Wow, nice work!
Bummer about the brake booster, would have been nice if it was OK and allowed for a test drive!
Old 02-27-2020, 03:57 PM   #112
tomasss
tomasss's Avatar
Originally Posted by JW240 View Post
Wow, nice work!
Thanks! I actually went for a test drive, that's how I've noticed it
I have my MBC set all the way back for now, so almost no boost, but I've heard the turbo whistling while picking up and that was the best part of the ride
Old 03-02-2020, 05:24 PM   #113
tomasss
tomasss's Avatar
New brake booster installed, also I have replaced ECT with a new Bosch unit just for sake of it.
Completely disintegrated wiring of the secondary coolant sensor has been replaced (connector #9144275 and connector pins #3523813) so now the dashboard temperature gauge actually shows something
I have also measured the oil pressure on the cold engine (around 15°C), it is close to 5 bars so there I should be safe
Old 03-07-2020, 10:44 AM   #114
tomasss
tomasss's Avatar
Another issue showed up...I have noticed the idle is not smooth anymore, after some debugging found out that cyl #3 is not firing. Injector is fine, but no spark.
Seems the Bosch ignition coil that I use with the wasted spark setup went bad, only 3 out of 4 spark outputs are giving actual spark. It was a used unit, so...new one on the way
To do at least something...I've replaced the damaged door locks!
Old 03-08-2020, 07:25 AM   #115
tomasss
tomasss's Avatar
As I have the doors already dismantled...I've installed the power lock to the driver's door, mounted the linkage and made an inspection window to be able to easily hook it up to the existing system
I just have to route the power lock wires through the door/pillar rubber grommet and I am done with this.
Old 03-21-2020, 04:30 PM   #116
tomasss
tomasss's Avatar
Wiring of the driver's door actuator is done, remote lock works perfectly
When I was on it, I also disassembled all doors and lubricated all the window and lock mechanisms.
Wiring of the knocksense is also done, now I am waiting for a custom set of new ignition leads to be able to dial it in on the running engine..
In the meantime last paintjob - the sunroof paint was faded so here goes the rattle can again
Old 03-22-2020, 02:25 PM   #117
tomasss
tomasss's Avatar
The front bump stops got my attention as I've noticed the material is completely disintegrating...ten minutes later I was already dismantling the struts
After further inspection, everything except the dust cover and the bump stops actually looks surprisingly well, the shocks are shiny new Volvo OEM units, the upper mounts are also in perfect condition...so I'll just replace the worn parts, clean it up, respray the undercoating and it goes back.
Old 03-27-2020, 07:06 PM   #118
tomasss
tomasss's Avatar
Some styling changes...old cracked side turn lamps has been replaced, I have installed clear version of it with amber bulbs
before
after
Old 03-27-2020, 07:15 PM   #119
tomasss
tomasss's Avatar
Also making progress with the struts...passenger side is done and back in the car. Some parts had surface rust so these has been wire wheeled, rust sealed and painted, bearings lubricated.
final assembly
driver's side before, passenger's after rebiuld
Old 03-28-2020, 03:35 PM   #120
V945
Hi! Do you have cruise control on this car? I see pulley for cruise control? but no other parts of this system.
V945 is offline   Reply With Quote
Old 03-28-2020, 06:02 PM   #121
tomasss
tomasss's Avatar
Not yet, few days ago I bought the complete cruise control kit from 960 plus the steering column switch but it is not installed yet.
I guess the pulley was always the same and not connected if the car was not equipped with cruise control...
Old 03-29-2020, 02:49 AM   #122
V945
Good luck, but probably you will have problems with console of vacuum cell, anyway make photo if possible.
Old 03-29-2020, 08:54 AM   #123
Vol242vo
Keep it clean...
Vol242vo's Avatar
You’re doing some amazing work brining life back to this one, love what you’re doing!
Old 03-29-2020, 03:35 PM   #124
tomasss
tomasss's Avatar
Not the first not the last problem on this car I've already checked the console in the pedal box, there is a mounting holder for the brake pedal vacuum valve but not for the clutch pedal valve. I'll have to fabricate something.
Thanks! Now with corona it's plenty of time...and while many friends are bored at home I keep myself busy every day
Old 04-03-2020, 03:48 AM   #125
tomasss
tomasss's Avatar
Some cosmetic fixes lately...working on the front grill and some other small imperfections.
The plastic tabs were missing so the fibre bondo and repainting took place.
