Old 05-29-2020, 08:09 AM   #151
Yep, you opened up the bottom end. Your engine will be stronger with good compression and will burn less oil.
How did you make measurements? With what tools?
Old 06-01-2020, 02:19 AM   #152
nordmaschine
forced instruction
nordmaschine's Avatar
Originally Posted by rijk View Post
B234F has different camshafts. More lift, different duration. Did wonders in my B204FT (together with ported head) before and after I dumped the stock shortblock with those stupid, heavy balance shafts for a newly build up B230FK.
I can check the numbers as I have both heads here, but IIRC they shouldn't have same numbers as they're totally different, as head part is concerned. Camshaft carriers ("upper head") are the same, but as the main part is concerned, dome diameter is different, valves are bigger on the 2.3, and generally they're not interchangible - 2.0 head on a 2.3 block would make for a stupid squish area and detonate itself into oblivion quite soon, while 2.3 head on a 2.0 block is going to slam the valves into block...
As for stupid balance shafts, I delete them for good preventive measure. But then you still have those stupid oil pumps that are NLA along with exploding pulleys...
But 204FT/GT blocks doo have girdles that don't fit 8v blocks.
However, my next 16vT build is going to use '98 B200FT block, B204GT head and B234F cams, just because I haven't tried those yet...
P.S.
That block looks really well worn. I don't think a hone is going to help much, it's probably due for an overbore, so I'd either go with that + custom pistons or sleeve the block...
Jetronic is romantic.
Whiteblocks
Old 06-15-2020, 04:43 PM   #153
tomasss
tomasss's Avatar
Still moving forward more or less
Oil squirters and new main bearings installed
Crankshaft back in place
Main caps and cross stay installed
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
Originally Posted by Wren View Post
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 06-16-2020, 03:39 PM   #154
tomasss
tomasss's Avatar
Converting the engine from reddishblock to redblock
Old 06-20-2020, 11:23 AM   #155
panas
Good evening to everyone here!
I am new member from Greece and this is the first thread i'm reading.
I like this project because I remember the time and effort that I spent to make my old Ford Taunus fast and safe. My name is Panagiotis.
Last week I bought a b204ft engine without the lh4 the tcu and the ezk116 . The half of the wiring harness is also missing...
I,m planning to install the engine on a Ford Taunus.
I found a complete car with the b200ft engine. Is it possible to use the ecu and ignition (chipped)and the harness of the b200ft to run
the b204ft with manually boost control?
I want the engine running with the factory settings because 200 bhp is more than enough for the old Taunus.
Do you suggest something different?
At this moment the car has a ford sierra efi engine controlled by megasauirt2 and ford edis4 wasted spark ignition . Do you know someone to transfer the fuel and ignition maps from the b204ft to the megasquirt controller? I tried to contact bijlsma by e-mail but my mail couldn't be delivered.
panas is offline   Reply With Quote
Old 06-21-2020, 03:00 AM   #156
JerryJS8
der Junge
JerryJS8's Avatar
Welcome to the board!
It would be better though if you started a new thread instead of hijacking an existing project.
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 06-21-2020, 04:27 AM   #157
panas
Thumbs up
I apologize for this, maybe Tomass could help me to contact with the man who modified his LH2.4
I will start a new thread.
Old 06-21-2020, 07:08 AM   #158
tomasss
tomasss's Avatar
Try bijlsmatechnicalinnovations@gmail.com
Old 06-21-2020, 01:46 PM   #159
panas
Many thanks Tomasss, I like the proccess of your project!
Old 06-26-2020, 04:29 PM   #160
tomasss
tomasss's Avatar
Custom pistons from Yoshifab are being made, in the meantime I am putting together whatever makes sense...
Front oil distribution plate
Cleaned, new radial seal & Volvo anaerobic sealant applied
Front of the block cleaned up
New oil pump o-ring seal
Oil pump cleaned & new radial seal
It started to look like engine again!
Old 06-28-2020, 03:56 AM   #161
rijk
rijk's Avatar
Default Thorough
Nice and thorough work.
The B204FT to B234FT conversion
http://forums.turbobricks.com/showthread.php?t=182821
rijk is offline   Reply With Quote
Old 06-29-2020, 05:07 PM   #162
tomasss
tomasss's Avatar
Thanks, trying my best to make sure I am doing it once and for good
The water/oil pipes going to the oil filter were rusty so the rust penetrator has been applied and two layers of hammerite over it...
Old 08-12-2020, 02:32 PM   #163
tomasss
tomasss's Avatar
More of the "in the meantime" work...pressure washed the engine bay today
before...
after...
It's not perfect as I had cold water source only, but thousand times better than before so I am happy the rest I'll clean up with some degreaser
Old 08-15-2020, 05:20 PM   #164
TurboDutch
Sow das geen half werk! Nice man!
TurboDutch is offline   Reply With Quote
Old 08-16-2020, 02:28 AM   #165
JerryJS8
der Junge
JerryJS8's Avatar
Looking good!
For all that grease, grime and crud in the engine bay, nothing works better than WD-40! Spray ALL THE THINGS and wipe clean with a cloth
Old 08-16-2020, 02:53 AM   #166
Sjeng
Sjeng's Avatar
Diesel also works very well.
You say you have new pistons ordered; is the block already bored?
Looking forward to seeing your results.
Old 08-16-2020, 03:42 AM   #167
TurboDutch
see previous page
Old 08-16-2020, 06:00 AM   #168
Sjeng
Sjeng's Avatar
Yes, my mistake.
Old 08-17-2020, 05:09 PM   #169
tomasss
tomasss's Avatar
Thanks for the hint with the WD40! I have tried the white spirit as I had full bottle of it laying around and that works really well too
So after some jumping around with piece of cloth soaked with the spirit, fixing all the small rust spots and repainting the frame rails & battery/airbox tray with paint and undercarriage/crossmember with the 3M undercoating, this is how it stands now.
Old 08-18-2020, 06:02 PM   #170
tomasss
tomasss's Avatar
Started putting parts back into the engine compartment!
Inspired by the >deck plate mod< I have modified my airbox using the 100mm ventilation grille with integrated metal screen
Old 08-19-2020, 02:51 AM   #171
Thumbs up
You wanna apply that pink sealant with a roller. I don't think applying a bead is the correct method.
Looks good!
Old 08-19-2020, 05:27 AM   #172
tomasss
tomasss's Avatar
Yep, well the front of the engine block has some pits and scoring so I was afraid if it will seal properly if the layer is too thin. The amount of the excessive sealant pushed out was negligible, so it will hopefully work
Old 08-19-2020, 08:08 AM   #173
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
erm, the pink sealant is for the 2 cylhead halves! it is essential to do it with a roller!
MadDog_945 is online now   Reply With Quote
Old 08-19-2020, 08:41 AM   #174
tomasss
tomasss's Avatar
On the head halves I'll do it with a roller, as the surface is nice and flat.
It is just a sealant that hardens when placed in between two metals, what might be the issue if it's used on the front oil distribution plate? What is the proper sealant then, when it got disassembled it looked like some thin sealant similar to the pink one.
Old 08-20-2020, 03:44 AM   #175
TurboDutch
No worries man... only cry-babies doing with roler :P
