Old 09-03-2020, 05:09 PM   #26
Originally Posted by Vol242vo View Post
Bumping this thread as there is finally a 1992 960 at a local junkyard. I’m unable to see the marking on the differential without dropping the crossmember or gas tank. For those that have pulled a G 80 out of a 960 what’s the easiest method? And although this tag doesn’t show the 1041 marking would that actually be on the axle itself rather than his crossmember?
Is that an IRS car? If so that diff will only be useful for an IRS application it will require 26 spline axles. 1 worse than the 27 spline that the solid axle cars use.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-03-2020, 06:53 PM   #27
Vol242vo
Keep it clean...
Vol242vo's Avatar
Ok, thanks Ben. Kinda what I thought, yes this was an IRS 960...so no go.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 09-04-2020, 04:58 PM   #28
mikep
The MP
mikep's Avatar
Originally Posted by sbabbs View Post
The white tag is located on the drivers side back of the rear axle housing. Lots of times it's covered in goop and you gotta scrape the goop to read the tag. IF it has 1041 on it has the g80. IF it has 1041K on it, 960's, it is even a better stronger g80..
Use WD40 and a plastic scraper/toothbrush.
