Old 09-13-2020, 09:44 PM   #51
Vol242vo
Keep it clean...
Vol242vo's Avatar
Brilliant idea with the painters tape and washers. I skimmed through the last few posts, are you powder coating or spray? It all looks fantastic.
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 09-13-2020, 11:09 PM   #52
escondidoron
escondidoron's Avatar
Thank you for the kind words. Ive been doing the washer and tape thing since I was a kid; back in my slot car days.
I am rattle can spray painting with etching primer and Rustoleum. Before painting Im sandblasting wherever possible. I.e. if it will fit in my blast cabinet. I prep all parts with acetone immediately before painting to ensure any lingering oil residue is removed. Paint consists of light coat of primer and 2 coats of color. After the finish coat of paint cures sufficiently to be able to handle I bake at 325F for 30 minutes. At assembly time I try to keep my hands clean and pre-fitting parts before painting helps to assure that they go together w/o interference. The resultant finish has proven to be quite durable.
Regards,
Ron
'73 145
'16 V60
A man must keep a little back shop where he can be himself without reserve. In solitude alone can he know true freedom. - Michel De Montaigne 1588
escondidoron is offline   Reply With Quote
Old 09-15-2020, 07:26 PM   #53
escondidoron
Does anybody know whether or not these two plugged holes have threaded nut plates behind them on my '73 145? I'm referring to the 2 plastic plugs on the cowl between the windshield washer reservoir/pump and the wiper motor, circled in the pic below:
They are pretty well aged and I think that I would destroy the plugs by attempting to remove them. If they are threaded I can use them to provide anchor points for a future A/C hose support.
Old 09-20-2020, 10:59 PM   #54
bgpzfm142
crossmember
bgpzfm142's Avatar
Unfortunately, no; they don't.
Your progress on this car is quite awesome, and I'm following with interest.
_______ THE FLEET (AKA good luck trying to park around here)
71 1800E | 73 144 | 74 142 | 74 145 | 79 242GT | 85 244 | 88 780 V6 | 93 945T | 2010 S80 V8
plus a Holden Commodore VT SS 5.7
feedback thread
bgpzfm142 is offline   Reply With Quote
