Old 08-20-2020, 11:16 AM   #1
martijn266
Default My '97 940se project
Hi!,
Got this nice 940se with "only" a couple of months ago and i was thinking about tuning this one properly. This tuning setup was the initial plan for my old 940 but that one didn't like the 2 minutes of revlimiter while doing donuts..... you probaly can guess how that ended. Cylinder walls were toast and one cilinder had no compression at all.
The new 940 is a much better start. No piston slap, no oil/coolant usage, stock headgasket and a lot of other signs of a healthy engine.
Now my setup
- td04 16t turbo
- 470cc bosch ev6 injectors (hoping to run a 19t on these aswell)
- ipd turbo cam
- 3" downpipe into a 2,5" simons exhaust system (thinking about a cat delete?)
- 3" maf from a volvo 960
Got myself a plx devices AFR gauge, and a proper VDO boost and oil pressure gauge.
martijn266 is offline   Reply With Quote
Old 08-20-2020, 11:17 AM   #2
martijn266
I only need to know if and what chip i should get, does somebody maybe have that answer?
Old 08-20-2020, 12:54 PM   #3
Sjeng
Sjeng's Avatar
You can try some of mine if you pm me your post address. I'm Dutch too.
I had a similar setup as you. 012/470cc opel injectors/18T.
Use at your own risk!
I got rid of the lean spot when it hits boost, and took fuel out at the top where LH turns ridiculously rich. Also retarded ignition a bit at high load, while increasing timing under cruise.
Old 08-21-2020, 05:03 AM   #4
Triebwerk
http://www.bijlsmatechnicalinnovations.nl/products.html
regards Mathias
[Austria]
Triebwerk is offline   Reply With Quote
Old 08-21-2020, 05:40 AM   #5
TurboDutch
Martijn uit zeeland? Ik kan je wel aan een 18Ttje helpen
TurboDutch is offline   Reply With Quote
Old 09-01-2020, 05:57 AM   #6
J2_
J2_'s Avatar
Jij wil iedereen aan een 18T helpen. Hou nou eens op met die babyturbo's man
J2_ is offline   Reply With Quote
