Old 09-09-2020, 02:25 AM   #1
James M
Bored member
James M's Avatar
Default 240 Front swaybar spacers
I've seen a few decades old threads about using spacers on the front swaybar bracket to clear oil pans on swapped cars. I was wounding if anyone still uses this setup and if so any recommendations as far as making them or buying an existing product. Only option I see is buying some aluminum and drilling some holes but If an existing product works why not avoid the hassle.
This is the type of thing i'm thinking of:
9-BB024-C0-B234-4-DE3-8901-18650-FD92-DCE
And a link to a some summit racing set
https://www.summitracing.com/parts/s...xoCLRsQAvD_BwE
Old 09-09-2020, 07:16 AM   #2
Broke4speed
Broke4speed's Avatar
I used scrap metal I had kicking around. I don't think anyone makes them for the 240.
If they did, they'd be overpriced for what they were, IMO.
1984 244/ AQ140A / M46
Old 09-09-2020, 08:39 PM   #3
mikep
The MP
mikep's Avatar
I used box aluminum.
Old 09-09-2020, 11:26 PM   #4
2turbotoys
Hybrid moments...
2turbotoys's Avatar
What kind of swap would get in the way of the sway bar? The steering rack and crossmember are also right there.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 09-09-2020, 11:46 PM   #5
James M
Bored member
James M's Avatar
Ide ask for thickness recommendations, but it wouldn't hurt to just hold it up and measure myself.
Needs to clear the filter on a whiteblock, just off the rack but no luck with the swaybar
Old 09-10-2020, 09:46 AM   #6
mikep
The MP
mikep's Avatar
Probably a front sump like old ford. I used spacers for addco bushings/brackets.
Old 09-10-2020, 10:33 AM   #7
740atl
educator monkey
740atl's Avatar
definitely an old ford.
Old 09-10-2020, 10:54 AM   #8
James M
Bored member
James M's Avatar
Nah ide perfer it run on 5 cylinders because it's only got 5, not because 3 have low compression
I'll probably get some measurements tonight and look into boxed aluminum as it's gotta be pretty thick, the filter sticks down a a ton.
Old 09-10-2020, 10:58 AM   #9
Plywood will work on a TBudget™.
Old 09-10-2020, 10:22 PM   #10
mikep
The MP
mikep's Avatar
^Ken is correct.
(But not balsa.. that’s just silly..)
Old 09-10-2020, 11:46 PM   #11
2turbotoys
Hybrid moments...
2turbotoys's Avatar
A small block of steel or aluminum would be super cheap/free to grab from a scrap pile and way better than wood, if you determine the approximate thickness I could probably find something to send your way. The shop I'm currently at has a huge amount of scrap to fab stuff with.
Old 09-11-2020, 01:24 AM   #12
culberro
culberro's Avatar
If you have energy suspension sway bar bushings and mounts, you can just use washers to space them where you want them.
My go to is some 1/8” or 1/4” aluminum flat bar.
Old 09-11-2020, 02:43 PM   #13
patrickstar
patrickstar's Avatar
STS Machining included some spacers with my LS mounts, maybe you could buy a few off of him
1983 Volvo 242 - 4.8/AR5
1984 Volvo 245
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 09-11-2020, 07:47 PM   #14
2turbotoys
Hybrid moments...
2turbotoys's Avatar
I forgot about those, they are just a rectangle of steel with 2 holes drilled in them. Super easy to make.
Old 09-14-2020, 06:43 PM   #15
patrickstar
The ones I got were slotted to make them easier to install, but it should be a pretty simple piece to drill yourself
Old 09-16-2020, 02:05 AM   #16
DrZiplok
DrZiplok's Avatar
1" square aluminium stock. Drill two holes, file one corner.
Necessary for non-droop sway and low CoG M5x swap, for example.
DrZiplok is offline   Reply With Quote
