Old 09-13-2020, 04:05 PM   #1
Turbo'd 24erty4er
Turbo'd 24erty4er's Avatar
Default Bosch red super coil in 940T
I have one of these and thought of using it in my 1994 945 T but not certain if it is really much better than the stock black coil.
I know the use of a ballast resistor is a requirement when used with points but is it safe as is with the electronic ignition system?
I have not found much information about this which is why I am trying to find out. It would look nice of course but only if it is compatible.
Turbo'd 24erty4er is offline   Reply With Quote
Old 09-13-2020, 05:44 PM   #2
hessam69
It's not needed.
The standard coil is more than good enough
Old 09-21-2020, 04:58 PM   #3
Canadan
Canadan's Avatar
it will kill the coil eventually, something about the difference in dwell.
at least thats what was explained to me when my stock lh2.2 volvo killed a brand new blaster 2 in 2 years. i threw the old stocker in and its still running on it fine after 6 years.
Canadan is offline   Reply With Quote
Old 09-21-2020, 06:24 PM   #4
PCH
I believe Bosch Super Red requires ballast resistor which is only bypassed during cranking. Feeding 12V continuously will make it fail sooner.
Old 09-21-2020, 10:05 PM   #5
arsenix
Spray paint the stock coil red. Cheaper, less issues, more power!
88' 740 GLE Wagon - B230FT, T5 Trans, MSII-extra, G80, 3" T->T Exhaust
- - > Project Thread < - -
My new project - 1990 740 SE Wagon
arsenix is offline   Reply With Quote
Old 09-22-2020, 03:13 PM   #6
I tried one on my 82 turbo. With an added ballast resistor because the unit requires 1.8 ohms for ballast and the stock ballast is .9 ohms. My car did not run as well as with the stock kjet coil which I ended up putting back in. But not before the red coil overheated and started leaking oil and also killed my ignition box.
