Old 09-14-2020, 10:02 PM   #1
adamsbees
Default custom wheel spec recs?
I want to have a set of diamond wheels custom made. I have a 780 IRS MK1
I will be running stock brakes and I do not want spacers!!!
I want the widest/deepest wheels I can safely run without;
excessive rub
rolling my fenders a bunch
running napkin tires
reducing steering angle
I will be running BC coilovers in the front.
If you have a good setup on your 700 please comment it below!
Thank you
adamsbees is offline   Reply With Quote
Old 09-14-2020, 10:55 PM   #2
2turbotoys
Hybrid moments...
2turbotoys's Avatar
willtheyfit.com helps ya do the math
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 09-14-2020, 11:00 PM   #3
I think the reverse ventilation slot lips in the hubs on the diamond wheels are in conflict with the calipers, good luck with the no spacers deal.
That said why not buy some Eikers from Ben and save yourself the heartache of trying to fit 20# + steel wheels?
Old 09-15-2020, 08:00 PM   #4
daijoubanai
waste of skin and blood
daijoubanai's Avatar
Just FYI, the IRS sticks out more than the solid axle by about 10mm, so you can't run as low of offset in the back as the front.
Diamond wheels also generally don't have much brake caliper clearance, so you'll probably have to run spacers anyway. I think the rear might actually be fine without spacers as the caliper doesn't stick out too much, but you'll most likely hit in the front. So a 10mm spacer on the front will help you clear the brakes and bring the spacing out to match the rear.
I have adapters on my car and run 30mm front and 20mm rear, so keep that in mind when ordering wheels. If you don't want spacers, you need to roll and pull out the rear fenders by about 10mm. Or you can just put a 10mm on the front. My wheels are 17x8 +37, with 225/45/17 tires. Offest after spacers is +7 front, +17 rear. Which means if you want to avoid spacers, you'll want wheels in the 15-20 offset range if you go with 8 inches wide.
Here's a picture of my set-up, and the rear tires will hit the fender lip if you don't roll it.
daijoubanai is offline   Reply With Quote
