Old 09-16-2020, 02:31 PM   #26
Originally Posted by aharres View Post
Thanks for the input Ben.
As for lifting the rear inner wheel, I'm not sure how much of a problem it is for my car at speed. Doing fast u-turns on the street, my car will definitely unload the rear inner wheel enough that I can't put any power down until I begin straightening up the wheel. Softening the rear bar would definitely help me here, but I'm also really enjoying how the car is handling with the 21mm rear bar.
So let's take the fast u-turn case: in the middle of the turn when my rear inner wheel is unloaded, can I stab the throttle and get the rear end to kick around for a fun little power slide on exit?
It seems to me that in this scenario, the wave device will engage and allow me to have my fun whereas a plain torsen won't be able to do much until I begin straightening the wheel.
It will be very difficult to get to a situation when you are going fast and hard enough on public roads that you will surpass the abilities of the wavetrac. As long as you don't have major setup issues it shouldn't be a problem from my experience.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-16-2020, 02:37 PM   #27
BeaverMeat
Not to hijack this thread... but, I'm in the same realm of choosing a LSD for the Volstang. I chose the TrueTracc over the WaveTrac because it has a better track record of reliabilty. The Wave may be "better" overall, but durability and reliability is more important IMHO... we are Volvo owners, are we not? ;) Plus, ripping apart a diff is beyond my capabilities at the moment.
I have a question for the diff experts. There are two types of TrueTrac offered. 3.73 and up, and the 3.54 and down.
Would it be stupid to use a 3.73 TrueTrac with a 3.31 gear? Whats the difference in the pre-load?
Old 09-16-2020, 02:40 PM   #28
cwdodson88
Originally Posted by BeaverMeat View Post
Not to hijack this thread... but, I'm in the same realm of choosing a LSD for the Volstang. I chose the TrueTrac... now, there is two types offered. 3.73 and up, and the 3.54 and down.
I believe that is going to be bolt pattern rather that preload. The 3.54 and down using a smaller diameter or different offset carrier to fit the ring gear, and 3.73 and up using slightly different carrier.
The Build Thread
SVEA - PUSHROD TURBO!
Old 09-16-2020, 02:42 PM   #29
culberro
culberro's Avatar
Volvo only used the 3.73 and up center section.
Go with the 912A588 part number, as it's a higher preload diff meant for a rear axle application.
Old 09-16-2020, 02:45 PM   #30
BeaverMeat
Good to know. I haven't been able to find a solid answer as my Google-fo isn't 100%. lol
Old 09-16-2020, 02:57 PM   #31
aharres
aharres's Avatar
Yeah that's what I was imagining. Are the wavetracs still going to be on sale when they come back in stock?
I just picked up some of your studs and nuts and I'm still trying to decide on wheel spacers. I want to space out the front a bit because I have maybe 2 or 3 mm of clearance between the tire and the strut housing at the moment. I think a mild 15 or 16.5 mm spacing will buy me some room without being in danger of rubbing on the wheel arches. The question is, do I want to add the same amount of spacing to the rear, or bump it up to 25 or 32 mm?
What would be the effect of increasing rear track width relative to the front? I guess it should soften the roll stiffness slightly, but I'm not sure what other effects it will have.
1992 volvo 240 wagon:
flavor - - - - > black on tan
suspension - - > stock + 23/21mm f/r arb
wheels - - - - > 14x6" enkei 92 + 215/70R14
drivetrain - - > M47 + 3.31 + open diff
engine - - - - > B230F + 2.5" exhaust
aharres is offline   Reply With Quote
Old 09-16-2020, 03:36 PM   #32
Wavetrac has a lifetime warranty. Not sure what Truetrac offers if anything.
Old 09-16-2020, 04:11 PM   #33
culberro
culberro's Avatar
Not much of one, if any. Shop mate had one in his Tacoma, and it wore the diff case out in probably 30k miles. No warranty or support of any kind from Eaton, they said it was all normal wear and tear... OK guys, there's over 3mm of play inside the diff, enough that he thought his wheel bearings were shot on the truck.
Old 09-16-2020, 04:46 PM   #34
I have not been notified of any price adjustments from wavetrac
If you have 3mm of clearance, its probably fine. if you want to space it out then go for it.
If it were me I would add spacers evenly unless you are trying to tune the grip balance. Too much oversteer? Make the rear wider. Too much understeer? Space the front more.
Old 09-16-2020, 08:30 PM   #35
mikep
The MP
mikep's Avatar
Originally Posted by 2manyturbos View Post
No, they are a clutch unit that is simply spring loaded. IOW, they don’t lock harder with more power applied to them the way most clutch limited slip units do.
Take a look here. There is a disassembled G 80 and you can see the clutch plates in the picture.
http://www.turbobricks.com/mods.php?content=art0027
Very cool. But weird. Thank you.
And it’s odd that it has the same code as a GM.
That is correct. The older high-preload was 411 suffix. The 588 is a harder case, better carrier bolt set up.
Old 09-16-2020, 08:49 PM   #36
2manyturbos
I also thought the Volvo G80 was a true locker until Kildea on here set me straight.
Old 09-16-2020, 08:58 PM   #37
Kjets On a Plane
Kjets On a Plane's Avatar
^yeah, not exactly, but might save your axle splines a little compared to the welded/spool & be a nice fuse/failure point or make the car tolerable to move around the driveway/yard if you have to push it dead/similar?
IDK what the service life of the clutches on an "always locked" G80 is/how well it works compared to a spool/how soon it's likely to scatter under duress as a hacked/molested turd polished thing, but it strikes me as less miserable to move around the yard/less horrible on your suspension bushings for DD use at the very least?
Lasted OK for me with 200hp for wet/snow weather fun/modded it in a weird way (still disengaged above x-MPH (30mph or so with vanagon sized tires on 245), but skinny vanagon tires/early 240 steelies/not that likely to 'splode it/not sure I'd call it a "performance" application/anecdotal.
Thought it was pretty predictable, but my driver skills aren't "all that" / rarely a hot shoe at any motorsport event to the extent apples-apples comparisons are possible.
How PSI a stock can support?
Always Be Crushing!
Old 09-17-2020, 10:32 AM   #38
BeaverMeat
So who is going to pay the labor?
Old 09-17-2020, 11:30 AM   #39
Probably the same person who will pay for the labor and parts for a truetrac?
Old 09-17-2020, 01:19 PM   #40
Fred Gwynne
Any comments on a quaife differential?
Fred Gwynne is offline   Reply With Quote
Old 09-23-2020, 08:55 AM   #41
tjanson
tjanson's Avatar
How about Auburn Gear Select-A-Loc? It's a clutch type with a e-locker feature that you can engage at up to 30 mph. $720 from Summit.
https://auburngeardiffs.com/aftermarket-catalog/
1993 245 DL; LH2.4, M47 - DD & Winter Beater
1978 242 GT - To Be Restored, someday
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
Old 09-23-2020, 09:30 AM   #42
JohnMc
JohnMc's Avatar
Probably good for hooining around. Selectable full locking. Heh, I did a 5 minute mod on my Toyota's factory rear e-locker so I can use it in 2HI. That's entertaining on rainy slick roads.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 09-26-2020, 11:57 AM   #43
aharres
aharres's Avatar
So I hear people talking about wearing out the truetrac on long sweeping turns (on a race track pushing a lot of torque I assume) Is this a real concern? Given that my plans are to build a hot na motor which won't be putting out a ton of torque, will the truetrac be reliable enough to last 5+ years of daily driving and hootin?
