Old 09-16-2020, 09:09 PM   #1
Sketchysedan
Default Need help with lh2.4 swap
I did an lh2.4 swap on my 240 the other week. I am having an intermittent issue with it where sometimes it will just crank and The fuel pump will not prime nor will I get spark. Earlier I had it running, shut it off to fill with water, tried to restart it and... same issue. 30a fuse to ecu’s and fuel pump is good, I re-checked any wiring I did and it all looks fine. I have all the grounds connected up, too. What should I check?
Sketchysedan is offline   Reply With Quote
Old 09-16-2020, 10:59 PM   #2
culberro
culberro's Avatar
Fuel pump relay, or spin the fuses.
Old 09-17-2020, 10:08 AM   #3
sbabbs
sbabbs's Avatar
Check the codes? Crank sensor?
Old 09-17-2020, 02:36 PM   #4
2manyturbos
And the ignition module. Without the spark signal you aren't going to get spark at the plugs or fuel pumps.
