Old 08-18-2020, 11:09 AM   #1
larsen
Question Looking for part id on wire terminals on newer volvos
Hi,
I'm retrofitting electrical seats on a car that dosent have those wires original. Does anyone know what these connectors are called? I'd like to buy like 50 of each if possible. Then I'll be able to get power and canbus to my seats. They go from the fuse box to the plug under the front seats. They're two different types.
As far as I know they're the same on 3.gen V70 and V60.
Photos : imgur
larsen is offline   Reply With Quote
Old 08-18-2020, 01:44 PM   #2
F*ck 12
Are they just single conductor wires? I'd cut those off and butt connector them together.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 08-19-2020, 01:49 PM   #3
larsen
single conductors yes. I need these exact pins as they're going into plugs at the fuse box and the front seats. These two on the photos are the two different ends, one into the fuse box and one into the front seat.
Old 08-19-2020, 02:06 PM   #4
oldschoolvolvo
oldschoolvolvo's Avatar
It looks like there is a “m” stamped on one of the contacts. Try sifting through Molex’s website for crimp terminals.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 08-21-2020, 02:40 AM   #5
OttoB
Finjector has good pictures of different connectors.
Old 08-21-2020, 10:29 PM   #6
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Take a pic of the terminal housing & post it. There is often a part number stamped into the housing. Type of terminal is dictated by housing type & sealed or unsealed, not the other way around.
Terminals are sized typically in thou - 060 series, 090 series, but sometimes in metric 1.5, 2.3 series , 2.8 series, etc. You need to measure the width of the aperture. Easier to figure out based on the male terminal. Load bearing circuits would likely be 2.8mm or larger, CAN & signal terminals are usually smaller.
The lower one looks like a Yazaki terminal, as many of them are on P1, P2
https://www.corsa-technic.com/item.p...ategory_id=111
My XR July2013 - 446AWHP @ 8K rpm Feedback Thread
Old 08-30-2020, 02:36 PM   #7
larsen
What about the terminal in the CS2-64 port on the CEM on P3?
Old 08-31-2020, 08:29 AM   #8
lookforjoe
lookforjoe's Avatar
I dunno. Got any pics of the housing? That other one may be a TS (Sumitomo) connector actually, the difference is in the opening notches inside the two tangs that stick up - one has an open area, the other looks like an old Camaro/Firebird "T" roof opening with a rib in the middle. The link I gave before is for that (TS) style, the regular Yazaki is slightly different. I'll take a pic. You need to look at the way the connector is assembled to compare.
EDIT- sorry for the confusion - the terminal is the one I already linked - the Yazaki looks like this for comparison:
This eBay vendor may be able to identify the terminal if you message them with a pic:
https://www.ebay.com/usr/ksvlooms?_t...p2047675.l2559
File Type: jpg Screen Shot 2020-08-31 at 8.40.27 AM.jpg (27.3 KB, 49 views)
Old 08-31-2020, 10:43 AM   #9
larsen
Here you'll see the photos I've got. I need to take better pictures of the housing. Only the square one, and not the round one, goes into the plug in the last photo
https://imgur.com/a/1ABhap0
Maybe this one?
https://www.elfadistrelec.no/no/klem...=10&track=true
Old 08-31-2020, 12:50 PM   #10
Question
Look at the plastic connector closely. You may need a magyfing glass, phone camera, etc and there will be a manufacturer marking.
I use wiring diagrams that usually tell me the connector and terminal information. If it's not listed I have a catalog with all the manufacturers of terminals and connectors.
It can also be really tricky to release the terminal from the connector without the proper terminal release tool.
Old 08-31-2020, 11:54 PM   #11
lookforjoe
lookforjoe's Avatar
Maybe this one?
When you say 'round' one - you are referring to the upper terminal in your hand, above? There are three connectors (plug?) in the last pic - I'm assuming you mean the black power seat connector ?
The terminal you linked is not that - the form is too square - yours has distinct rounded edges to it.
Old 09-04-2020, 10:25 PM   #12
lookforjoe
lookforjoe's Avatar
Look through these pages :
https://www.volvopartswebstore.com/s...duct=1154565#1
https://www.volvopartswebstore.com/s...x3FMGaUOIbH8q4
