Old 04-23-2018, 05:54 PM   #1
muppetman342
Having too much fun
muppetman342's Avatar
Question Yoshifab Catch Can or Provent Feedback?
Thinking of upgrading my PCV system to keep all that oil out of my intake. I'm currently eyeing the Yoshifab setup or the Mann Provent. The Yoshifab setup looks nice, but I can't help but think I'd get more filtering out of the Provent, and the Provent is cheaper. Tbh not entirely sure how to justify the Yoshifab price other than that it looks nice, but to me it seems like it wouldn't be any more effective, maybe even less, than running some generic can inline with the stock breather.
Anyone have any experience with either and how much cleaner they did/didn't make your intact tract?
muppetman342 is offline   Reply With Quote
Old 04-23-2018, 10:16 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
I have never heard of the Mann product, looks nice and simple.
I have used the yoshifab unit and liked it a lot so I just purchased a second unit for my wagon but next time I might pick up one of the Mann units for one of the other cars.
Old 04-23-2018, 10:29 PM   #3
muppetman342
Having too much fun
Did you notice a difference in the amount of oil in your intake with the yoshifab kit?
Old 04-23-2018, 10:47 PM   #4
thelostartof
unbalanced chemical
I would say less, but the 744 doesn't really put a lot of DD miles on it to much these days so I only had maybe 3000 miles on it over the last year or so. Once I get the 744 back together and running I can say for sure, but in those 3000 miles there was little to zero oil heading into the turbo, I am sure it helps that my HY35CW has less than 50k miles on it as I bought it new 10+ years ago as most TB'ers are running either self rebuilt turbos or 150k+ mile used units. Once Yoshifab ships my current kit I paid for I can get it on the wagon and see if that helps but even then I do not have a ton of oil in the intake system currently but my dipstick does pop out from time to time.
https://oe-products.mann-hummel.com/...ProVent_en.pdf
I always liked mann products but this looks great. myself I would prefer the Provent 400 unit. The Provent 200 is $140 tho so not a lot cheaper than the yoshifab unit unless you add in all of the block and other fittings.
My largest complaint on the yoshifab kit is that the fittings are a bit small being -10 but since there are two points for flow into the catch can maybe not as much of an issue.
Old 04-24-2018, 08:59 AM   #5
Homer
OEMplus++
Homer's Avatar
I have been running the provent 200 for the last 40k miles. Changed the filter ~3k miles ago. I've never had oil buildup issues in my turbo(s). Even at higher boost. I kept the stock oil separator and connected the provent after that. It also drains to the sump via a check valve.
-Jacob:
2017 allroad - Comfy DD
Old 04-24-2018, 09:11 AM   #6
Stiggy Pop
Stiggy Pop's Avatar
I've bought and returned both (due to packaging constraints with my setup). I would run the Mann if it suited my needs, it's a nice piece. It is large, check the dimensions on the Mann site.
Yoshi can is nice but, yes, really just a generic can. I returned mine with the intent to order a Saikou Michi because I could have it built to spec.
'79 242
943 pickup
Old 04-24-2018, 09:15 AM   #7
oldschoolvolvo
oldschoolvolvo's Avatar
Here is a more budget-friendly option that I am using. You will need to gather the appropriate fittings to connect to your setup but overall works well. I don’t have oil in my pre-turbo piping (I removed the included filter and ran a line to the pre-turbo pipe) Can also be plumbed to drain back to oil pan if desired.
https://rover.ebay.com/rover/0/0/0?m...2F262628636931
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 04-24-2018, 09:30 AM   #8
Tfrasca
Tfrasca's Avatar
+1. I have the Yoshi can in mine, and it's not as baffled as it could be. I just put some stainless steel scrubbers in the can to try to help with that, but the Provent filter system looks really nice.
Old 04-24-2018, 10:48 AM   #9
gofaster_940
What way would the Provent be plumbed into the existing system ??
gofaster_940 is offline   Reply With Quote
Old 04-24-2018, 01:20 PM   #10
classicswede
Volvo upgrades
Very much like the look of the provent.
Will have to get one and give it a try
Old 04-24-2018, 01:47 PM   #11
Ursan
Bored Member
Ursan's Avatar
Stuff here.
https://forums.tbforums.com/showthre...rovent&page=11
how psi a stock can support?
I admit I'm stupid...
Old 04-24-2018, 01:55 PM   #12
Chuck W
Chuck W's Avatar
I've got a ProVent in my '80.
Had to relocate it, once I finally got the fresh ZF rack in there.
It's big, and I don't have it plumbed to drain back into the pan, but I haven't really noticed much collecting in it. I may try and move it higher to the PS of the bay at a later time.
'78 264GLE
'97 854 T5 (Manual swap/COP/16T/P2R brakes)
'80 264GLE (B21FT/M46/MS) - SOLD '77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 04-24-2018, 02:10 PM   #13
Ursan
Bored Member
Ursan's Avatar
HERE and HERE
No photos
Old 04-24-2018, 02:39 PM   #14
Provent's are the ****.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-24-2018, 03:01 PM   #15
Homer
OEMplus++
Homer's Avatar
Should give you a good idea of the plumbing.
Stock breather box--> Provent--> tee to intake manifold--> Pre turbo pipe
Old 04-24-2018, 04:11 PM   #16
Chuck W
Chuck W's Avatar
No photos
Should go to the posts in my build thread, where there are photos.
Old 04-24-2018, 04:50 PM   #17
Ursan
Bored Member
Ursan's Avatar
Still no photos.
Are they shared from FB?
Old 04-24-2018, 08:18 PM   #18
Chuck W
Chuck W's Avatar
Still no photos.
Nope. From my personal host site.
I just added the pics, something was being dumb, evidently.
Old 04-25-2018, 03:47 AM   #19
JW240
All idiot, no savant
Provent can be had from China-alixpress much cheaper
Going with a provent 200 too on my b230, running in series with the stock pcv box. Homer gave me the idea.
Pcv box directly to turbo intake gives oily mess and even some water turned into ice which damaged the compressor..
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 04-25-2018, 07:52 AM   #20
muppetman342
Having too much fun
Well the heater element on the intake hose should prevent the ice if it's hooked up
You planning on having the provent drain back to the block anywhere? I'm debating just putting barbed fitting on the drain side of the stock breather and draining into there, don't see why that wouldn't work.
Old 04-25-2018, 08:58 AM   #21
thelostartof
unbalanced chemical
Same thing I was thinking, but with a YoshiFab kit on the way for my wagon maybe not. I like that the Provent is 1".
I guess I will get one of these for my other cars.
Old 04-25-2018, 11:29 AM   #22
PCH
I used Provent on VW pancake motor. It's a good part for the money.
On the related subject: draining oil back into the crankcase from the catch can should be avoided whenever possible.
Old 04-25-2018, 11:30 AM   #23
oldschoolvolvo
Seeking to understand...can you explain why?
Old 04-25-2018, 11:47 AM   #24
PCH
Because other than perfectly good reusable oil the can will contain water condensation, fuel and blow by contaminants mixed with it. Think of an oil catch can as filter- whatever it caught doesn't need to go back.
Old 04-25-2018, 12:33 PM   #25
Homer
OEMplus++
Homer's Avatar
You might want to have a chat with every engine manufacturer out there. The stock oil separator drains back to the crankcase. The provent is just doing a better job of separating the oil from the blowby gases. There's no functional reason not to drain it back. You should be getting your oil up to temp so the water vapor and other volatiles will evaporate.
