Old 05-28-2020, 06:48 AM   #1
aristg
El Greco Capitano
aristg's Avatar
Question AC / PS bracket
Anyone who has pictures or part number for b21/23 bracket which can support ac + power steering pump - the newer style ?
I am NOT talking about the old style York compressor bracket which looks like a square missing one side which on top has the old triangle style pump.
The goal is to mount newer style rotary AC and 91+ steering pump with integrated oil can on a B21.
aristg is offline   Reply With Quote
Old 05-28-2020, 08:02 AM   #2
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
That wasn't used until the B230 (1985 in the US). Not sure if the block casting is the same in that area. You can look up parts here:
https://www.volvopartswebstore.com/c...car-parts.html
My XR July2013 - 446AWHP @ 8K rpm Feedback Thread
Old 05-28-2020, 09:16 AM   #3
bobxyz
bobxyz's Avatar
These should help:
B230 Accessory bracket on a B21?
-92 vs 93 240 AC Brackets
Old 05-28-2020, 12:44 PM   #4
aristg
El Greco Capitano
aristg's Avatar
Great info thanks !!
It looks the B21/23 casting is missing a bolt hole right next to the distributor opening. This was added on B230 as you said. However by looking at the links you posted, there are bracket configs that can be bolted (two versions of it).
B230/B200 or in general later engines config: blue markings
B21/23: red markings (this is actually be a B21 on the pic by bobxyz)
Sorry for the poor drawing skills
Old 05-28-2020, 05:32 PM   #5
bobxyz
bobxyz's Avatar
The B21FT blocks that I've seen ('82, '83, '84) all have the 4 red circled studs.
I think the normal B230F blocks also have the same 4 mounting holes, but use bolts instead. I'm not sure if the mounting bolt location by the distributor is used for anything - the one below isn't tapped.
Here's a side-by-side picture, '84 B21FT on left (with a broken stud) and '89(?) B230F on right (click on pic for bigger size)
Old 05-28-2020, 09:38 PM   #6
aristg
El Greco Capitano
aristg's Avatar
I was under the impression that all redblocks were the same. Apparently they have some minor differences.
Here is a bracket (alternator - ac) which was removed from a late B200 engine. Also it fits perfectly to a donor skinny rod non squirter B230 block i got.
This one for example does not fit to my B21. Its part number is 1336937.
Btw my skinny rod B230 is tapped at that location !!
Old 05-31-2020, 03:49 AM   #7
aristg
El Greco Capitano
aristg's Avatar
Here is another ac / ps engine bracket from a late model b200f. It features the latest ps pump Z shaped bracket (tensioner below the pump almost horizontal - older bracket has the tensioner upright close to the distributor). It also has the latest rabbit ear ac on it and no ps pump bushings ! Go figure ...
Old 05-31-2020, 09:29 PM   #8
283SD
I have one from an '87 245. I think that it had the remote P/S res,I don't know if that matters. It's sitting on the floor in my shop and in the way.
Old 06-05-2020, 02:29 PM   #9
aristg
El Greco Capitano
aristg's Avatar
@283SD Why don't you take a pic of it ? The pumps have 2 different mounting ways (tensioner below pump & tensioner next to distributor)
Old 06-06-2020, 01:24 PM   #10
283SD
Haven't set up to send pictures yet. The a/c p/s was bolted to the block,tensioner next to the distributor
