Old 06-21-2020, 05:06 PM   #1
740stu
Exclamation MAF sensor 1989 740
Hi,
Wondering if anyone had experience with a Bosch MAF.
Part number 0280 202 035 or Volvo number 1306967.
Mine is broken and need a new one...
These seem very rare anyone know if I can change it for a later 740 MAF? I know they are physically different and bolts holes may not line up but not sure if there is a difference in operation/signal output?
740stu is offline   Reply With Quote
Old 06-22-2020, 07:46 AM   #2
hessam69
turbo on non turbo?
Old 06-22-2020, 10:14 AM   #3
white855T
There must be some wrecking yards that will have old Volvo's laying around that will have maf that you can snag. Try calling around, maybe Volvo specialist?
Old 06-22-2020, 12:47 PM   #4
The Librarian
That part number is for an air flow meter. A MAF won't work with that system.
Here's a NOS AFM in New Zealand for a very reasonable price.
https://www.trademe.co.nz/motors/car...2667987076.htm
Old 06-23-2020, 04:36 AM   #5
740stu
Thanks for all the help just looking at getting that one from New Zealand but the website only lets people from Australia and New Zealand join...typical
Old 06-23-2020, 12:10 PM   #6
The Librarian
We have a lot of members in that part of the world. Try placing an ad in wanted and see if there's anyone who's willing to buy it and ship it to you.
Old 06-24-2020, 05:36 AM   #7
OttoB
Try Sweden for example this company
http://www.maskinobil.com/
Old 06-24-2020, 08:27 AM   #8
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
How about some pics of your engine bay? Which EMS does your 740 have? Since Volvo used a wide range of systems depending on market requirements, it's most likely NOT the US market-standard LH2.4 or Regina/Rex systems from that model year.
Would help us determine if you are looking up the correct part. Depending on your system, it may or may not be able to generate system codes to help determine the component failure. Also to get advice on the symptoms you are experiencing you could elaborate on why to think you need it?
My XR July2013 - 446AWHP @ 8K rpm Feedback Thread
Old 06-24-2020, 08:34 AM   #9
white855T
https://www.skandix.de/en/spare-part...ensor/1009737/
Part discontinued. Hiperfauto's link is the correct part. It is very much not a standard part.
Old 06-24-2020, 12:26 PM   #10
OttoB
Op has B230ET, I guess. It uses Bosch Motronic ECU, and it doesn't have AirMassMeter (measuring kg/h), it is AirAmountMeter (measuring m3/h) like K-Jet. It is a flapper and measures position of that flapper with potentiometer. Contact of poti wears out and it can give false value causing uneven running and hesitation.
Year 1989 it is great year for Volvo, they had all Bosch systems in their fleet. K-jet, L-jet, LH 2.2, LH 2.4, Motronic and carburetors.
