Old 08-29-2020, 11:14 AM   #1
jhendrick71
Default Wanted - Super Ride
I am looking for advice on a 1988 240 frame off restoration project - see picture. The suspension that was installed by the person doing the work is not to my liking from the perspective of ride ( too stiff ) and the stance of the car seems not right as well.
I am looking for advice on how I can fix it so I end up with a truly super ride ( the perfect set up combo of super struts, shocks, springs, etc) - even if I have to start over. What's you advice as well as any technical specs I should make sure I conform to as I am working with a new guy now... thanks
jhendrick71 is offline   Reply With Quote
Old 08-29-2020, 11:18 AM   #2
jhendrick71
Old 08-29-2020, 11:37 AM   #3
Dan
Watching the World burn
Dan's Avatar
Made the pic work.Ride is subjective, put it back to stock for the best compromise, but many prefer stiffer.
What kind of driving will you do? what kind of ride do you like? What is the current suspension setup? so many variables
1985 Chevy TPI V8 740.
Old 08-29-2020, 03:38 PM   #4
jhendrick71
I am looking for a smoother ride ( its stiff ) - The current suspension setup is all new as this was a frame off resto - I am not sure what the components that the restorer put in - I asked him to stay true to original Volvo specs for 1988 - I will put on lift on Monday and try to get a picture and a list of whats there - just trying to figure out what parts OEM makes the best suspension kits to create a responsive smooth ride - if one was starting from scratch - what would you look to do? Where can I find the right specs ( coils, shocks, etc) for a 1988 240?
Old 08-29-2020, 04:14 PM   #5
Fa182
Stage 1
Fa182's Avatar
Fa182 is online now   Reply With Quote
Old 08-29-2020, 05:23 PM   #6
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Old 08-29-2020, 11:17 PM   #7
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
In addition to pics, it would help to get an precise list of the actual parts/part numbers/manufacturer (F&R springs, dampers, rear shocks, suspension components ) the installer used, since we can't tell that from a pic of the struts, etc.. That would help figure out whats going on. Also you don't say what wheel & tires you are running, which will also impact ride quality significantly.
Since these don't have a frame that can be removed, I'm unclear what you mean by frame-off restoration. Did you strip to the shell, acid bath/media blast then repair & reassemble?
My XR July2013 - 446AWHP @ 8K rpm Feedback Thread
Old 08-30-2020, 03:32 AM   #8
Fa182
Stage 1
Fa182's Avatar
Since linking to Dropbox somehow doesn't make the photo show up, here it is.
Old 09-01-2020, 09:00 AM   #9
jhendrick71
I am putting this car on the lift later this week to get all the current setup specs so I can get better feedback - will post..frame off resto means we took everything off before repairing frame, bath, prime and repaint - then we started over with replacing everything
Old 09-01-2020, 02:12 PM   #10
lookforjoe
lookforjoe's Avatar
Sounds like a plan. Car looks amazing , btw - would be nice to see some detail shots of the paintwork etc
Old 09-01-2020, 03:35 PM   #11
Dan
Dan's Avatar
If you replaced all bushings, sometimes they need to break in. I'd drive the car a couple of hundred miles and see if anything changes before you start spending money
Old 09-01-2020, 05:01 PM   #12
Restore it to stock.
Old 09-01-2020, 05:08 PM   #13
Dan
Dan's Avatar
See post 3, Was actually thinking of you when I typed that, but it is good advice
