Old 02-03-2018, 02:08 PM   #1
Jack
Banned
Jack's Avatar
Default kaplhenke 240 upper offset strut mounts
anyone got a picture how the hardware goes together.... https://www.kaplhenke.com/collection...t-strut-mounts
going for the "first setting" mild and would be easier to see where the bolts/hardware goes rather than trying to figure it out
Thanks
Jack
Old 02-03-2018, 02:27 PM   #2
Pro Sneaker Peddler
Go for the max caster setting.
Old 02-03-2018, 02:29 PM   #3
Jack
Banned
Jack's Avatar
I only have stage one penis so I cant show off with that much caster
Old 02-03-2018, 02:49 PM   #4
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Position 1
Position 2
Position 3
Old 02-03-2018, 03:12 PM   #5
Jack
Banned
Jack's Avatar
Thank you !
and the insert faces down ?
and the lock washer goes on top I take ?
Old 02-03-2018, 05:57 PM   #6
MDVLN
MDVLN's Avatar
Yes
Yes
Example
Old 02-04-2018, 07:57 AM   #7
photoman327
photoman327's Avatar
Got to get mine installed!
Old 02-04-2018, 04:44 PM   #8
ryan242v
ryan242v's Avatar
One would think for $180 some simple instructions would be included. Go figure.
2009 Schwinn Leguna 50!! Scooter Puff Jr. 5,500 miles!
1998 S70 T5M, 264k miles, needs something
1987 244 DL, 234k miles (Current Daily Driver)
1979 242 DL, 500k miles, B230FT, M45, 3.31 diff
1973 1800ES awaiting restoration, not togethor
1971 Camaro, my highschool car, rusting away
1969 Suzuki T500 Titan II
ryan242v is offline   Reply With Quote
Old 02-04-2018, 06:04 PM   #9
photoman327
There are no instructions with oem but I did ask Ben to mark mine when I picked them up.
Old 02-04-2018, 06:35 PM   #10
propav8r
F*ck Edgar
propav8r's Avatar
If only there was a Turbobricker who is employed as a technical writer... Maybe that person could offer their services to create instructions for these parts...
Oh wait...
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 10-10-2018, 09:38 PM   #11
carver
Redblock for life.
carver's Avatar
Just for reference there is another position but it requires another hole to be drilled and tapped. If you have the tools you can do it yourself, you can get the particulars from Ben. Or ask nicely before buying if he'll do it for you. This was the only way I could avoid the stock spring from rubbing on the back of the strut tower.
Position Zero
carver is offline   Reply With Quote
Old 10-18-2018, 09:48 AM   #12
Fred Gwynne
Fred Gwynne is offline   Reply With Quote
