Old 09-20-2018, 09:27 AM   #26
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
it's a td04. even if it's a huge td04, it's still a tiny turbo that has been over-populized by fwd'ers that like tire spin and don't like making power. (oh and IT CAME ON EURO SPEC R's DAWG)
Megasquirt Tuning!
Old 09-20-2018, 09:43 AM   #27
Marvelous3
Who engineered this?
Marvelous3's Avatar
Originally Posted by tryingbe View Post
This is done with a T04BV trim, .63 a/r turbine housing, ATP ultimate wastegate, stage III turbine wheel on a Dodge 2.2 8 valves with a big valves head, boost from min 7psi at 3.5k creeping slowly to 12.5psi at 6.5k (by accidental design and no boost creep issue once min boost is turned up) . T04E 50 trim wheel would be a more efficient wheel which means it will make even more power at the same boost level and wider powerband.
Top red line is boost.
That's interesting info, thanks!
Old 09-20-2018, 09:49 AM   #28
t8fanning
8v are still cool, right?
t8fanning's Avatar
Originally Posted by Marvelous3 View Post
I mean, I say that I'd be good at 250-270, but who knows. The plan is to be able to daily drive this car so I don't want it to get so race car that it's unreliable or not driveable around town.
Nothing is set in stone but I don't want something that doesn't make any boost until 5k. It's a f+t motor so it won't be a super dog off boost but I don't want an all or nothing set up.
I daily drive my 8 valve with a efr 7670. You can make it as reliable as you want. But for your goals, I'd probably do a GT2860 or GT2871r. They're small and don't flow much air, but it sounds like it will do what you want. What engine management are you using?
1982 242 Turbo.
Old 09-20-2018, 10:21 AM   #29
Marvelous3
Marvelous3's Avatar
Micro.
Old 09-20-2018, 10:26 AM   #30
culberro
culberro's Avatar
PM Harlard, he has a turbo that he needs to sell.... definitely would fit your goals.
Old 09-20-2018, 10:40 AM   #31
t8fanning
t8fanning's Avatar
Micro.
Perfect. I'd look at Haralds turbo first. If you don't like that, I'd look at a gt28. If you don't like that, I'd get an efr 6258.
Old 09-20-2018, 12:41 PM   #32
JW240
All idiot, no savant
JW240's Avatar
I've been happy with a 60/63 T3. Cheap option, low tech. Might make it till the power goal. Mine with Cosworth turbine housing is running 200-220 hp at low ish boost.
Old 09-20-2018, 12:56 PM   #33
Tfrasca
Tfrasca's Avatar
I'm living through this exact scenario right now. My car probably makes 250ish at 18 psi on a good day with the 19t. It's very quick given the 4.30 rear end and the lighter 142 chassis, but after a few months, it's not enough and I'm upgrading the turbo to a Borg Warner.
Old 09-20-2018, 01:21 PM   #34
Marvelous3
Marvelous3's Avatar
^yeah I think at the end of the day a 19t, while an easy "direct swap", is too small. Which bw turbo are you looking at?
Old 09-20-2018, 01:37 PM   #35
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
S382 of course
(Kidding)
Didn't know Harald was selling his unit. That could be cool too. I didn't want to (openly) mention/suggest the... "budget" stuff as I've had insults lobbed my way in the past and I don't want your thread to turn into that.
Old 09-20-2018, 01:55 PM   #36
Tfrasca
Tfrasca's Avatar
I got an s252 sx-e with a small .48 housing from AGP. Should spool pretty quick but get me to 300 whp. If for some reason it doesn't there are a bunch more turbine housing options.
Old 09-20-2018, 01:57 PM   #37
t8fanning
t8fanning's Avatar
You should just order a bigger turbine housing now. I'll bet you get sick of the 0.48.
Old 09-20-2018, 02:52 PM   #38
Tfrasca
Tfrasca's Avatar
I don't know. I do love the spool of the 19t.
Old 09-20-2018, 02:53 PM   #39
t8fanning
t8fanning's Avatar
I expect you'll love some real flow even more.
Old 09-21-2018, 04:46 AM   #40
cosbySweater
cosbySweater's Avatar
Put the biggest turbine housing you can fit with your manifold
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
Old 09-21-2018, 09:07 AM   #41
linuxman51
linuxman51's Avatar
not a bad suggestion really
Old 09-21-2018, 11:15 AM   #42
Marvelous3
Marvelous3's Avatar
Been talking to Greg at go-autoworks and I think a t3/t4 50 trim is going to be the winner. They can put the wastegate on the exhaust housing so wont have to deal with a custom manifold.
Old 09-21-2018, 11:57 AM   #43
tryingbe
Boosting along.
tryingbe's Avatar
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
85 GLH 367whp
00 Insight mpg > yours.
Old 09-24-2018, 03:14 PM   #44
linuxman51
linuxman51's Avatar
if you go that route, make sure you get one of the better housings and not the old school 5 bolt housing.
Old 09-24-2018, 03:33 PM   #45
JimmyMelbs
Alot of people run CheapO eBay t04e turbos with .63 exhaust housing. Should be good for 300 with supporting mods. I got mine for $180aud.
JimmyMelbs is offline   Reply With Quote
Old 09-24-2018, 03:49 PM   #46
cosbySweater
That's like the go to for budget build, cheap as hell and usually pretty reliable, also kinda laggy
Old 09-24-2018, 05:04 PM   #47
Marvelous3
Marvelous3's Avatar
He's got both 4 bolt and 5 bolt outlet T3 housings in stock. I think a 4 bolt with a .63AR should work fine. I'm shooting to have this whole thing together by the spring SE meet. Fingers crossed.
I'm not going the chinabay choo choo boi turbo route. I just don't want to **** with some $200 turbo that may or may not work out of the box and is definitely not going to be good long term when a brand new turbo from garrett can be had for under $700.
Old 09-24-2018, 05:34 PM   #48
Pro Sneaker Peddler
The 5 bolt housing should be OK as long as you don't use the internal gate portion.
Old 09-24-2018, 08:01 PM   #49
tryingbe
Boosting along.
tryingbe's Avatar
External wastegate is great and all but internal wastegate can work well.
Old 09-24-2018, 08:52 PM   #50
Pro Sneaker Peddler
Had that. Worked ok with a t3/t4. Not so much with my last turbo.
