Old 09-24-2018, 09:39 PM   #51
tryingbe
Boosting along.
tryingbe's Avatar
Not so much with my last turbo.
What turbo is that?
85 GLH 367whp
00 Insight mpg > yours.
Old 09-24-2018, 09:52 PM   #52
Pro Sneaker Peddler
Originally Posted by tryingbe View Post
What turbo is that?
GTX2860R. Would definitely stick with one of the larger, externally gated Garrett housings for that one.
Old 09-24-2018, 11:45 PM   #53
300+hp on the shelf club
If you get a 240 turbo 5 bolt .63 housing. Then you won't have to machine the step off the 90+ manifold. Just have to upgrade the studs on the 90+ manifold to ten mm studs.
Old 09-25-2018, 03:34 AM   #54
cosbySweater
cosbySweater's Avatar
You would also have to hog the hell out of the exhaust housing. Just because the AR is the same doesn't mean the exhaust wheel will fit in there. Alot more variables then AR
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
cosbySweater is online now   Reply With Quote
Old 09-25-2018, 03:23 PM   #55
Marvelous3
Who engineered this?
Marvelous3's Avatar
Where would a holset hx35 compare to a 50 trim t3/t4? It should be larger correct?
Old 09-25-2018, 03:43 PM   #56
tryingbe
Boosting along.
tryingbe's Avatar
Do you have dyno or boost logs?
Old 09-25-2018, 03:48 PM   #57
tryingbe
Boosting along.
tryingbe's Avatar
Look up the compressor map of each and compare is the best way.
Here's an excel turbo compressor map calculator.
ftp://terveen.mynetgear.com/shares/M...bo_v2_beta.xls
Old 09-26-2018, 01:08 AM   #58
cosbySweater
If I was going to do a holset I would do a he341, spooled about the same as the eBay 57trim but at the same time if it's your daily driver why make a mess out of it? For a daily the tcam 16t on a n/a bottom end is my personal go to
Old 09-30-2018, 08:58 AM   #59
OttoB
Just in the middle of mapping B230F+T, 16T and A-cam.
280 Lbsft on gasoline and 320 with RE85. Likes to knock on gasoline at 1,2 - 1,3 bar, and timing is dropped around 10 Deg. Takes nicely more timing with RE85, about 16 Deg.
Engine is still on Dyno, but hopefully in car next week.
Old 10-08-2018, 09:15 PM   #60
2turbotoys
Salaminizer
2turbotoys's Avatar
I still have what I pm'd ya about, haven't put it up for sale yet....
2006 V50 T5 AWD 16 PSI +
