Old 09-19-2018, 04:48 PM   #1
lorcand20
Question my 940 b230fk 350hp build
new to these build threads but here we go. bought this 940 se last year and added the manual boost controller and boost gauge, car did go well but after reading a few threads on her decided to see how far i could pull the old Volvo. the pics to follow are of the car and the parts that i have bought for the car i still need to buy a clutch? and an inter-cooler? this is my first Volvo build so any help or advice would be much appreciated.
1997 940se
3076 ebay for now but if it works goo i will change to a hx35 holset.
tial 46mm waste-gate
Bosch 550cc injectors
stage 3 chipped fuel and ignition ecus with wasted spark
dizzy blank and gaskets
3 inch MAF
IPD turbo cam and gear
i also have a gripper diff and a AEM A/F ratio gauge. any help on the gripper diff mod would be much appreciated also thanks for reading and comment if you have any advice for me.
lorcand20 is offline   Reply With Quote
Old 09-19-2018, 04:50 PM   #2
lorcand20
can you see the images? i added them but the are not showing?
Old 09-19-2018, 05:43 PM   #3
Pro Sneaker Peddler
You're hotlinking page URLs rather than image links.
Old 09-19-2018, 05:44 PM   #4
Pro Sneaker Peddler
That ebay 3076 looks awfully familiar to what I have. Looks like it also has the copycat Borgwarner compressor wheel.
Also, that cam gear is not going to work in your car. Just toss it in the garbage. It's no good. Get a two-piece gear for a round-tooth belt from STS Machining, Nuke, or Yoshifab.
Old 09-19-2018, 05:56 PM   #5
lorcand20
i think my car is a square tooth anyway lol so what way do i put the pics up?
Old 09-19-2018, 06:10 PM   #6
Pro Sneaker Peddler
Right click on picture, select "copy image URL".
Old 09-19-2018, 06:38 PM   #7
lorcand20
sorted, thanks. is there much benefit from the adjustable cam gear or would i get away with using the standard one?
Old 09-19-2018, 09:30 PM   #8
Pro Sneaker Peddler
Yeah, you have to set the cam to 1mm of opening the intake valve at tdc. Usually translates to -3 to -4 degrees at the cam gear.
Old 09-20-2018, 02:47 AM   #9
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
nice car.. im stoked to see what it turns into ;)
Old 09-20-2018, 05:10 AM   #10
K9 240
K9 240's Avatar
Hi - Looks like exciting times ahead!
A couple of things -
What is the spray pattern on those injectors? I found that anything other than a narrowish cone will lead to an uneven idle. This wasn't a problem to me - the problem came when it failed the MOT due to emmissions (this was on Siemens Deka 60lb injectors).
Also the injectors may be marginally large for the size of AMM you have. LH2.4 will learn ok but when you go to full throttle it may go very rich. (that's why you bought the Afr gauge) May not be a problem for you - I have different chips to you - but if at full throttle you get a rich bog or are just embarrassed by the cloud of smoke you leave behind you, consider putting the guts of your old AMM into a larger section of pipe (details are on here somewhere).
K9 240 is offline   Reply With Quote
Old 09-20-2018, 05:39 AM   #11
mocambique-amazone
Don't waste your time with this differential. Buy a proper one or stay with the open diff.
Best year of 940 you could find
The double mass flywheel won't stay with over 250 HP
You spent a lot of money already, not TB-style
Buy the TTV conversion kit from Dai.
And some suspension stuff.
Best is: rhd, yeah.
Be a happy 940 driver, Kay
Old 09-20-2018, 05:43 AM   #12
mocambique-amazone
Forgot:
First do a zero one tune and the wasted sparkspark with everything else original.
And listen to Harlan. Much easier with a two part cam gear. You will be able to modify your original one in the same way IPD did and I prefer the steel ones personally.
Old 09-20-2018, 12:00 PM   #13
Sweep
Interesting, I wonder whether that's why mine idles like a pig on the DEKA injectors, what did you use instead? I've got a HY35 bolted to mine.
Old 09-20-2018, 12:08 PM   #14
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Awesome paint colour!
Old 09-20-2018, 01:07 PM   #15
lorcand20
thanks man, i will buy a 2 piece gear the ipd one looks quite cheap lol
Old 09-20-2018, 01:08 PM   #16
lorcand20
i hope it turns out fast
Old 09-20-2018, 01:13 PM   #17
lorcand20
not sure on the spray pattern. the man i bought the chips of said to buy that MAF and that size of injectors not sure if he had tried it him self but i hope it works out ok lol what size of injectors are u using now? will the standard MAF in a bigger pipe be better than the one i bought? thanks for the info man
Old 09-20-2018, 01:18 PM   #18
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Not sure I see 350 hp here...looks good though
B5.5 passat wagon, low af sexier than most wagons here.
Old 09-20-2018, 01:34 PM   #19
lorcand20
Best is: rhd, yeah.
thanks for the reply, i heard if you wield the governor its a good enough job. where would i buy a diff as and open diff is no fun what sort of flywheel will handle the power as i haven't bought a clutch yet so i can buy the right one to fit the flywheel.
Old 09-20-2018, 01:35 PM   #20
lorcand20
Forgot:
i will try that first to make sure it works lol
Old 09-20-2018, 01:39 PM   #21
lorcand20
i hope to get near it tho lol
Old 09-20-2018, 06:25 PM   #22
Sjeng
Sjeng's Avatar
If he pushes 1.8+bar... why not.
Old 09-20-2018, 07:03 PM   #23
thelostartof
unbalanced chemical
thelostartof's Avatar
350bhp or whp? Injectors seem a bit small for that goal.
With a stock head, stock manifolds it is going to take a lot lot lot of boost to make 350bhp.
Old 09-21-2018, 07:14 AM   #24
K9 240
K9 240's Avatar
lorcand20 - I'm still using the Deka injectors. I'd use the larger AMM you have - if you find you need to change it you can put your old AMM guts into a slightly larger tube. There is a formula to work it out somewhere. I bought larger injectors when I went +T - I knew they were too big for my set up as it was then so wasn't expecting it to be perfect. When I put a larger turbo on & my rich bog was still there I realised that just having a 960 AMM & calling it done was not enough. I'm using a 3.5" tube now, slightly too big - possibly not quite rich enough at full throttle but does not bog at all. May line the tube with a 1 or 2mm something if I need to richen it up.
@Sweep - Still have the same injectors - when this thread came up -
http://forums.turbobricks.com/showth...=326991&page=2
(see post#33 by gross polluter & the video at #52) I saw the light! - just ignore the usual TB complimentary chit chat. I put the injectors in a Kjet head so now the nozzles are a lot closer to & shoot straight at the back of the intake valve.
Old 09-21-2018, 07:17 AM   #25
lorcand20
I've a man making me a tubular exhaust manifold, and il port the head and gasket match when building back up. What size of injectors do u recommend?
