Old 09-20-2018, 01:01 AM   #1
GeneralBurrito
GeneralBurrito's Avatar
Default Opinion on IPD's high flow air filter for the 240?
I think it just came out a few weeks ago and I'm wondering what you guys think about it. I just feel that having more air is better, but that also has a higher chance at damaging the maf.
https://www.ipdusa.com/products/2108...-240-non-turbo
Old 09-20-2018, 01:19 AM   #2
holtzboy
Honda CRV DD WTF
holtzboy's Avatar
I highly doubt there would be a measurable difference, especially for an NA. I would rather swap out $7 paper filters and not have to clean/dry a filter that may not clean up as good as it's original state.
1. 86 244DL- 1st car & owned for 16 years, 25mm sways, back to stock springs w/ KYB shocks, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
2. 87 244DL - Sister-in-law's DD
3. 93 244DL - Step daughters DD
4. 84 242DL - Next project car
My feedback thread
holtzboy is offline   Reply With Quote
Old 09-20-2018, 01:22 AM   #3
GeneralBurrito
Yeah, it's just nice to see IPD is still thinking about the bricks. Would it have more of a difference on a b cam swapped NA? I'm already going to get the IPD sport exhaust, so having a higher flow filter could also help a bit.
Old 09-20-2018, 11:42 AM   #4
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
It's less restriction. To each their own.
-Stephen
#mclovethesenuts
Old 09-20-2018, 11:48 AM   #5
JohnMc
JohnMc's Avatar
I'd stick with regular filters. You pay more for this, and it will not make any difference whatsoever.
I'd be willing to bet a $20 bill that you couldn't even tell a difference on a dyno, much less on the road. The stock filter simply isn't undersized, and only costs you some power if it's half clogged.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 09-20-2018, 11:54 AM   #6
culberro
culberro's Avatar
In dusty conditions, the IPD filter just doesn’t do a good job... marginally better than a K&N.
It is washable, so that’s nice.
Old 09-20-2018, 11:55 AM   #7
Old 09-20-2018, 11:58 AM   #8
JohnMc
JohnMc's Avatar
I was going to say - the only way to improve flow is to either:
1) Increase surface area - and in the case where a filter has to fit into the stock dimensions, it would require a lot more 'folds'. And this doesn't seem to have significantly more folds.
2) Increase the size of the holes in the filter medium - so air has less resistance going through. This lets incrementally larger sized particles into the engine. Which may or may not be a bad thing, depending.
FWIW I run my PV's motor with no air cleaner at all - DCOE bellmouths sucking air straight in. Because racecaR.
Old 09-20-2018, 12:14 PM   #9
GeneralBurrito
Mostly driving in city and sometimes freeway, it's not that dusty around here other than when there's road work being done. The filter seems tempting, but I'll wait a bit and see if any reviews pop up on the website.
Old 09-20-2018, 12:21 PM   #10
JohnMc
JohnMc's Avatar
I'd bet the blue coloring drives a lot of sales. If it looked like a regular paper filter, few people would bother.
Old 09-20-2018, 12:26 PM   #11
Too bad smokedfan isn't still on here that would complement his circus engine bay nicely.
Old 09-20-2018, 12:32 PM   #12
240240
Solely ruined TB
240240's Avatar
Fail all the smogs with that dirty 007 AMM
240240 is online now   Reply With Quote
Old 09-20-2018, 01:18 PM   #13
Thor
Thor's Avatar
We'll since we're jumping off the deep end with fancy air filters someone should also come up with a silicone pipe to replace the ****ty accordion hose that's likely cracked some where and to reduce the air turbulence going into the manifold. +10hp definitely to be gained.
1991 240 M-47 daily driver
Build thread: 91 240
Feed back: Here
Thor is offline   Reply With Quote
Old 09-21-2018, 06:58 PM   #14
Jack
Banned
Jack's Avatar
Lol ipd is pretty much **** these days.
Old 09-23-2018, 10:17 AM   #15
240240
Solely ruined TB
240240's Avatar
Tell me more about this silicone pipe
Old 09-23-2018, 11:07 AM   #16
Wren
Porkchop Sandwiches
Wren's Avatar
I Paid Double.
The most expensive place to buy just about anything.
Old 09-27-2018, 04:54 PM   #17
KeizerBrickGuy
Sh*t pot stirrer
I RockAuto most of my parts, unless I need something ASAP, then I'll pay the convenience fee and discount at IPD. Also, yes, more about the cool-aid silicone race pipe?
Old 09-28-2018, 06:59 PM   #18
brian smith
Yeah, I'd buy one of those without any claim of turbulence reduction. Something that holds up to the typical rubbing against engine compartment walls and obstructions.
the howdeedoo:
Old 09-30-2018, 11:58 AM   #19
freevolvos
freevolvos's Avatar
looks ok if you just had to wash it and never buy a new one that would be ok, I'm might buy one, i work in a very dusty place
Old 10-01-2018, 04:13 PM   #20
Thor
Thor's Avatar
If I were to build an NA motor and was forced to keep the stock B230F intake. I would probably buy one as well. just saying. . . .
Old 10-01-2018, 09:27 PM   #21
brian smith
Nobody in the world will ever again be forced to do such a thing by anything other than their own delusions. Commit your scarce duckets now or forever hold your damn peace.
Old 10-02-2018, 12:53 PM   #22
quillc
yv1a.com
quillc's Avatar
This filter will keep the bugs out, but that's about it.
Whether you should buy a filter like this depends upon your use case.
If you ever drive your vehicle in dusty conditions, then this is a poor choice for you.
If you daily drive your vehicle, this is a poor choice for you.
If you only drive occasionally on the street or at the track, go for it.
The way filters like this achieve 'more flow' is simply to filter less well (aka poorly). Less restriction = more flow at the same pressure drop.
Very often in vehicles, it isn't necessarily the filter that is the greatest restriction. Its the ducting and intake.
Again, it all depends upon what are doing with the vehicle.
Chris
www.yv1a.com
Old 10-02-2018, 03:06 PM   #23
GeneralBurrito
So far I'm only driving to school and back and occasionally to stores. At most only around 50-60 miles a week. And it's rare to get dusty here.
Old 10-02-2018, 03:07 PM   #24
Did it spool yet?
Old 10-12-2018, 12:24 AM   #25
freevolvos
freevolvos's Avatar
Yes it spooled but the extra dirt wore the blades off the turbo
