Old 09-25-2018, 07:25 AM   #1
JSD
Default Twin Turbo setup
Hi,
I'd like to set up a twin turbo on my inline-6 engine. After studied the twin turbo system, I see an unusual turbo setup. While the intake of the conventional parallel system is designed to feed air to the turbo individually, the one I found on a diagram is one turbo is fed by the other. However, the exhaust sides are alike, yet, it won't called a compound or 2-stage turbo set up. Could anyone please tell me the advantages and disadvantages of this setup?
JSD is offline   Reply With Quote
Old 09-25-2018, 09:21 AM   #2
JerryJS8
der Junge
JerryJS8's Avatar
Why do you want to go twin turbo? Just for the bling or do you have a certain power curve or HP goal in mind?
Parallel turbos, smaller turbos for fast spool
Compound turbos for high turbo boost pressure
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 09-25-2018, 09:26 AM   #3
JerryJS8
der Junge
JerryJS8's Avatar
Originally Posted by Duder View Post
People are throwing in "sequential" and series/compound turbo systems into this discussion...
Probably worth clarifying some terminology.
  • Twin: two identical turbos in parallel
  • Series: two differently-sized turbos, one feeding the other. The larger turbo is the LP (low pressure) and feeds the smaller turbo (HP) on the compressor side. On the exhaust side, the small turbine feeds the larger one. Sometimes called "compound" setup, but that's actually something else (see below).
  • Sequential: can be parallel or series. Indicates that there is staged control of airflow, i.e. one turbo handles all of the flow at low engine speeds and the other is brought in to help at higher speeds...in sequence. Implies a change over time.
  • Turbocompounding: geared connection between turbine and engine crankshaft. Converts exhaust energy back into mechanical shaft power to the crankshaft of the engine. Like an inverse supercharger.
In with Duder b4 Duder
Old 09-25-2018, 09:27 AM   #4
Vincent Gagnon
Vincent Gagnon's Avatar
Originally Posted by JSD View Post
Hi,
Wow!
Awsome idea!
Can't wait to see the car run!
I subscribe to this thread!
Keep us updated!
Old 09-25-2018, 09:32 AM   #5
JohnMc
JohnMc's Avatar
So, if I'm picturing the picture you've described correctly, it's parallel on the turbine/exhaust side, and sequential on the compressor/intake side?
Could you just show us the pic you're describing?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 09-25-2018, 09:39 AM   #6
JSD
Old 09-25-2018, 09:50 AM   #7
JohnMc
JohnMc's Avatar
Ahhh... My work blocks most pic hosting. It's in the first post already.
I'm not an expert (wait for Duder, he is), but I would tend to suspect that you would need very carefully selected turbos. Since the compressor will be seeing very different conditions. They're both ultimately passing the same CFM, and assuming they're properly specced, raising the boost pressure the same number of PSI, but the second one will probably need to be smaller. Same hotside, though?
Not sure how boost control would work either, but I'd assume you'd run the first compressor at a set psi its output, and the second one at a higher psi on its output.
All in all, I really just think you're going to get differing amounts of backpressure on each set of cylinders, depending on what the two turbos are doing. Which would affect how much air flows into each set of 3 cylinders.
Might work better on a diesel where the a/f mixture isn't critical (at least, not very, lol rolling coal) and you're going for some sky high boost pressures that a single turbo can't do. I.e. tractor pulling type setup?
Old 09-25-2018, 10:01 AM   #8
Benjam83
Moar Volvos than Queen B
Would the one on the right be for "packaging issues" where there just isn't much room under the hood? That's the only benefit that I can come up with...
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 09-25-2018, 10:19 AM   #9
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
You could use a small turbo to spool up a big one with that setup
1980 242 Turbo
2004 V70R
Old 09-25-2018, 11:45 AM   #10
lummert
lummert's Avatar
So when is someone going to try using the exhaust pressure for turning the crankshaft? Volvo D13 already has a version of this.
Old 09-25-2018, 11:50 AM   #11
JohnMc
JohnMc's Avatar
Old 09-25-2018, 07:12 PM   #12
JSD
AFAIK, the compounding setup uses 2 different size of turbo but in this case, parallel system, it uses the same size turbo. A little modification has been done on the intake side. So what’s the reason of this mod? Any advantages/disadvantages?
Old 09-25-2018, 07:24 PM   #13
Vincent Gagnon
Do it please!
There is some great ideas here:
http://www.turbobricks.net/forums/showthread.php?t=280
and here
https://forums.tbforums.com/showthread.php?t=344166
and here
http://www.forums.turbobricks.com/sh...ad.php?p=44518
and here
http://forums.turbobricks.com/showthread.php?t=198758
and here
http://www.turbobricks.org/forums/sh...d.php?t=337584
and here
http://forums.tbforums.com/showthread.php?t=8700
All amazing build, working great and it's really simple.
Please keep us updated on your project.
Old 09-26-2018, 04:26 AM   #14
JSD
This is the planning stage. I need time+knowledge+money. Please be calm.
Old 09-26-2018, 07:54 AM   #15
Jack
Banned
Jack's Avatar
It will never spool
Old 09-26-2018, 07:58 AM   #16
centason
Knipex=welfare queen
centason's Avatar
Just install Owen Development quad turbo 4 banger.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Old 09-26-2018, 11:10 AM   #17
740740
Solely ruined TB
740740's Avatar
There could be an entire subforum of twin turbo threads.
740740 is offline   Reply With Quote
Old 09-26-2018, 12:37 PM   #18
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
If you have to ask...
Hello My Glorious!
Old 09-28-2018, 10:05 PM   #19
freevolvos
freevolvos's Avatar
been doing it for a while look up wright r3350 uses a power recovery turhine they realized in the 30's adding inlet psi wasn't helping but using the exaust side of a turbo and hydraulic coupling to the crank shaft to help turn the crank
Old 10-03-2018, 08:50 PM   #20
955IsAlive
Single twin scroll turbo? I6 is perfect for it.
955IsAlive is offline   Reply With Quote
