Old 09-30-2018, 03:37 PM   #1
1971Gold142
1971Gold142's Avatar
Default Is the Rallye Gauge water temp sensor specific - B20F?
Hello,
I have the Rallye Gauge cluster in my 1971 142E and as I just replaced the engine with a rebuilt B20F do I need to swap temp sensors for my gauge to work properly? I installed the engine with a standard temp sensor on the FI head but still have the old sensor that worked great.
Thanks in advance
71' 142E
1971Gold142 is offline   Reply With Quote
Old 09-30-2018, 03:59 PM   #2
John V, outside agitator
clean the hex really good and look on the flats of the sender...Stamped in might be something like 0-150..
Look at gauge..is it the same range?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 09-30-2018, 04:09 PM   #3
Vincent Gagnon
Vincent Gagnon's Avatar
0-120 if memory serves.
Old 09-30-2018, 04:39 PM   #4
1971Gold142
My old sensor that worked reads 120 MAX so I'll stick with that. Thanks!
Old 09-30-2018, 04:50 PM   #5
Well the big thing is does the marks on the sender match --0-120 or 0-150, whadd EVAR.
Old 09-30-2018, 04:53 PM   #6
Good. that's why we should stick with VDO or Moto-meter..they mark their senders on the flat of the hex...even stock idiot light for oil pressure senders ---in metric so 0,4-0,6 bar
Old 09-30-2018, 07:07 PM   #7
The temp sensor, oil pressure sender and fuel sender are specific to the Rallye cluster. Only the oil pressure sender is readily available.
Old 09-30-2018, 07:35 PM   #8
1971Gold142
Great info hiperfauto!
Old 09-30-2018, 08:28 PM   #9
Aside from the lack of a little tiny Saab logo, those look identical to the same things in a Saab "De Lux" instrument cluster of the same generation....All of them..
And a sender is a sender...
Old 09-30-2018, 09:02 PM   #10
Considering the 4 gauge GT cluster works with all the stock senders, I'd say a sender is not a sender. The fuel gauge will work backwards on a Rallye cluster with stock sender and I doubt Volvo would have sold a special temp sender if the stock one worked.
http://forums.turbobricks.com/showthread.php?t=309835
Old 10-04-2018, 08:07 AM   #11
OttoB
Default Sensor values for R-Soprt, Rallye and VDO gauges
I made measurements with 12,5 V for Rallye and VDO Series 1 water temp gauges. For R-Sport I bypassed that voltage regulator and after couple tests 7,5 V supply voltage was found to be ok.
Potentiometer simulated the sensor
VDO Series1 Water
Temp Ohm
40 103
80 48,6
100 30,7
120 19,7
Rallye 12,5 V
Temp (C) ohm
C 40 104
1. 71,2 60
2. 99,2 32
Red/black 110 25
H 120 20
R-Sport 7,5V
temp ohm
50 90
80 50
100 30
120 21
So use standard VDO sensor with 120C stamping on hex, or sensor from 73-> 140, with ->72 sensor reagings on the gauge will be lower.
