Old 10-02-2018, 10:01 PM   #26
eli323232
eli323232's Avatar
Do you have pictures of the shifter setup?
eli323232 is offline   Reply With Quote
Old 10-03-2018, 08:26 AM   #27
Dadssleeper
Dadssleeper's Avatar
His photo shows that its made by CBF so used Google and found them.
http://www.cbfperformance.net/#!/Gen...258/category=0
Search around you can even find a video of someone shifting it.
Old 10-03-2018, 09:04 AM   #28
JohnMc
JohnMc's Avatar
I've got pics of the install in my build thread: http://forums.tbforums.com/showthrea...166061&page=52
You have to take the tail housing off and cut the shifter rod. It's not that bad though, just make sure that the 'center' plate that holds all the bearings and gears in the front part of the case doesn't try to come off with the tail housing, they're all held together with the same set of bolts. There's nothing complicated going on with the tail housing itself, but you'd be in a world of pain if that center plate backed out.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-03-2018, 09:17 AM   #29
poulrais
poulrais's Avatar
You have to be VERY patient cause it took a LONG time for JohnMC to get his unit.
1990, Volvo 740 16v +T
Old 10-03-2018, 09:21 AM   #30
poulrais
poulrais's Avatar
I have a 240 and its why I will be looking into a short shifter kit, or cutting the tunnel out and pulling the hole back where its needed, or possibly even even using a tunnel from another car...I don't have the transmission in front of me yet or have the adapter from deeworks, but I am seeing as things develop more good things are happening as far as parts and options.
Once I get a hold of a transmission and an adapter I'll figure out what needs to be done, but I have driven a 370z with a cd009 and loved it I think it will be perfect for my 16v turbo project.
I myself own a 370z Nismo and I love that tranny though it's noisier than I expected, probably because I have a custom race clutch installed on the car.
I'll be running a 3.31 final on my 740 with the swapped and build T6. But since I'll push twice the HP I have in the 370z (around 700 hp, the Nismo has 350 crank hp) I think that the setup will be pretty good.
Old 10-03-2018, 09:24 AM   #31
JohnMc
JohnMc's Avatar
Absolutely worth noting. It was a solid 3 1/2 months from order to delivery. Actually, that reminds me, he still hasn't sent the offset shifter.
Old 10-03-2018, 09:32 AM   #32
poulrais
poulrais's Avatar
Yeah I was wondering if that order was fulfilled in a faster way than the original one. This guy isn't going to be in business very long if he keeps delivery times of that magnitude.
Old 10-03-2018, 09:38 AM   #33
JohnMc
JohnMc's Avatar
I sent him another email. On Aug 23 he said he'd get that out to me, but no real specifics. I should have been bugging him more frequently, I guess.
Old 10-03-2018, 10:20 AM   #34
eli323232
eli323232's Avatar
Yeah I meant that toward the OP with the yoshifab custom setup.
Old 10-03-2018, 01:12 PM   #35
rb92673
I have an early prototype that is pretty ugly. It's a Lemons car so I just needed it to function for a race last weekend. I will post a picture of a production unit when I have it on the car.
