Old 10-02-2018, 01:35 AM   #1
VolvoGuy123
VolvoGuy123's Avatar
Default Need advice! rear spring rate for a 940 T Sedan?
So I have a 1995 Volvo 940 (turbo) sedan. I have Bilstein HD's up front and Bilstein "tourings" in the rear along with a set of (40mm) lowering coils (Proparts 43435807) and I recently purchased a "rear adjustable spring perch kit" (kaplhenke) but it is made to use rear springs without "the pigtail" on top (2series?) so I am left to buy another set of (Eibach 5" universal) coil springs for the rear but I don't know what spring rate to go with? Now, I am not picky with the suspension and I am not planning on much track use but I do want it to ride and handle well! Now, I came to my own conclusion of (5"OD x 15"L) and around 200-250lbs (spring rate) for the rear? Anyone have any quick advice before I order these tonight? Thanks, I appreciate any insight! ;)
VolvoGuy123 is offline   Reply With Quote
Old 10-02-2018, 01:40 AM   #2
VolvoGuy123
*FYI; I have stock sway bars, most new bushings, ball joints, wheel bearings, IPD Chassis brace, IPD Panhard bar, etc. Just in case any of that matters? lol.
Old 10-02-2018, 03:16 AM   #3
Sjeng
Sjeng's Avatar
My estimates show that a 200lb rear spring, gives a ride frequency of 2.1Hz on a 940. Already quite firm. (Assumptions: 290 kg sprung corner weight, 1.43MR^2)
As a general rule of thumb your rear frequency should be approximately 0.3Hz higher than the front. If we want 1.8Hz in the front you need approximately 300lb springs.
So what are you running in front? And what dampers are you going to use?
Old 10-02-2018, 03:23 AM   #4
Sjeng
Sjeng's Avatar
One other thing, I see stock 940 rear springs are 375mm. Your 15" are 381mm, and stiffer. So 15 appears to be a bit much if you do not want your car looking like a tractor.
How much adjustability do you have with the adjustable perches? What ride height do you want?
Old 10-02-2018, 04:09 AM   #5
VolvoGuy123
All the info I have is in my post. (kaplhenke) gives a choice between 11" or 9.5" (length) rear springs for the "adj. spring perch kit" but I measured my stock springs and they were 16" and my "lowering springs" I have on the car now I haven't yet measured. I honestly don't know much about suspension setups, hence the reason for this post. Maybe the (Eibach 5" x 11" x 200lbs) is the way to go? I don't know.
Old 10-03-2018, 02:40 AM   #6
VolvoGuy123
think i figured it out? lol. If I did and all goes well I will post specs so other 7/9 series owners don't have to go thru the same situation with this or a similar kit. Thanks, ttys!
Old 10-04-2018, 08:20 AM   #7
mikep
The MP
mikep's Avatar
Don't forget the motion ratio of the rear arms. Any spring behind the axle will give a higher wheel rate.
Originally Posted by Pretentious_E View Post
... the fun kind of dickheads.
mikep is online now   Reply With Quote
