Old 10-10-2018, 09:17 PM   #26
Texas240
Prius Owner
Texas240's Avatar
there's an off the shelf pump you can get that is already spaced out... why add something else to leak?
Cause I'm using these spacers for 2 years now with out leakage. What vehicle is this non spaced out water pump with shorter pulley and has the output on the passenger side that I'm not remembering?
93 245 LS Engine Swap Project
Old 10-10-2018, 09:22 PM   #27
cosbySweater
cosbySweater's Avatar
You can also hack off the bottom of the truck bracket. Hog out the holes and flip it sideways and use a 68 inch belt. Ugly as hell but it works as well. Just use the stock truck tensioner
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
Old 10-10-2018, 09:37 PM   #28
2turbotoys
Salaminizer
2turbotoys's Avatar
Thanks for all the answers..so many options. This is why I love TB and posted here instead of a random LSX forum.
2006 V50 T5 AWD 16 PSI +
Old 10-11-2018, 09:43 AM   #29
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Although I really like LS1Tech Hybrids & Conversion forum... But, it has been infiltrated by perfectionists with too much money. There is a delicate balance between Sloppy and Perfect($). Aim for the middle on a budget. LS engines just work, don't overthink it.
#79WDP
2010 Porsche Cayenne S - DD
2010 Cadillac Escalade ESV - Wifeys ride - 194k stock
2006 Cadillac DTS - Sons ride - 193k stock mint
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
Old 10-11-2018, 10:18 AM   #30
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
part number is in my 940 thread somewhere.
not sure why you'd want a passenger side outlet since all the volvo radiators are on the driver's side.
ah here it is ACDelco 251-734. truck spaced accessories. went through a lot of trouble to keep the truck spacing, and I really couldn't tell you why I did that other than a/c and a lack of suitable bracket choices at the time. or maybe it was something to do with the brackets and a new crank pulley, I'm not sure. that info may be in the build thread.
Megasquirt Tuning!
Old 10-11-2018, 07:14 PM   #31
Texas240
Prius Owner
Texas240's Avatar
Because the pulley setup I'm getting for my supercharger is in the way of that drivers output.
Old 10-11-2018, 07:25 PM   #32
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
F Body or 2010+ Camaro SS water pump will work then as the output is on the passenger side.
... I thought 240s had more hood clearance? If so the stock Truck WP will work, but you need the truck intake manifold to match. (LS1/LS6 short intake manifolds do not work with the Truck WP)
Old 10-11-2018, 07:54 PM   #33
Texas240
Prius Owner
Texas240's Avatar
your missing my point. F body water pump the pulley is thicker and takes up space, Camaro SS output is on the drivers side
Old 10-11-2018, 08:14 PM   #34
240wagonguy
2008+ silverado water pump if you want the output on passenger side
240wagonguy is online now   Reply With Quote
Old 10-11-2018, 08:27 PM   #35
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
My bad on the 2010+SS it is drivers side.
I am using the F Body WP and it seems thin enough for a 960 swap. BUT you are correct that the pulley snout seems 2-3" farther out than it needs to be compared with the crank pulley.
IIRC I may have had to stick with the LS1 WP due to the Truck based accessories even with the ICT Billet kit.
Old 10-11-2018, 08:34 PM   #36
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Interesting option!
I wonder how much lower the tube is than the pre-2007 truck WP? Again 240 might not care.
Also the WP is still threaded for a mechanical fan and IDK how much shorter that "snout" would be? + potential offset issues w/ Truck vs LS1 accessories.
Old 10-11-2018, 09:54 PM   #37
Texas240
Prius Owner
Texas240's Avatar
I have the 96 camaro water pump with outlet on passenger side front of pump. On a 240 you get 1/4" of space between the pulley snout and 960 fan when the engine is in the all the way back position with the sts mounts.
Interesting option!
All you need is a 3/4" spacer like I have and it sets in the right position for F body accessories.
Old 10-11-2018, 10:42 PM   #38
55superbeetle
If you're going to buy the pump and accessor brackets anyway, buy the 05 corvette pump and get the matching balancer. It gives you so much more room for activities in the engine bay.
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 10-11-2018, 11:32 PM   #39
Texas240
Prius Owner
Texas240's Avatar
The one thing to look at is if you do choose to go all corvette accessories is that the ac compressor has a different bolt mounting pattern and the those compressors are a constant on variable pressure compressor compared to on/off cycle type.
Old 10-12-2018, 05:07 PM   #40
M.H. Yount
M.H. Yount's Avatar
Sanden 5 series with Alan Groves low mount for Corvette spacing works perfectly.
Old 10-12-2018, 06:40 PM   #41
Texas240
Prius Owner
Texas240's Avatar
and theres a solution
Old 10-12-2018, 09:38 PM   #42
2turbotoys
Salaminizer
2turbotoys's Avatar
nvrmind, have to think more about it
Old 10-17-2018, 10:08 PM   #43
2fast242gt
Do you have a cobalt?
Texas, use a truck pump and put the neck off the front I tapped in a morso neck
1983 242dl
*6.0 lq4 swaped* Build thread
