Old 10-10-2018, 02:45 PM   #1
Pumba
Question Chippet 850 T-5 - Boost issue
Oi there lads..
I got a '96 850 T-5 (B5234T) with white injectors and a stg 3 chip, it's got a ****ton of power and goes like a bat out of hell..
But if I floor it (pedal to the basement) it'll start - well sounds like studdering and it kinda halfway cuts out..
It'll start doing it at about 3300-3500rpm..
It's only doing it when at full throttle and not if I accelerate at 3/4 throttle, even if I go to 5000+rpm..
Could it be the boost protection kicking in or could it be that I'd need a bigger downpipe than 2.5" ?
(as far as I have been able to figure out, the boost protection shouldn't kick in with a sgt3 chip, or am I totally lost here?)
Hope someone in here got the "Guru"-sign lit
Best Regards
Pumba is offline   Reply With Quote
Old 10-13-2018, 11:58 AM   #2
ovlov760
ovlov760's Avatar
Check the condition and gap of your spark plugs. IIRC the factory gap is .028. If you're running more boost you may want to narrow that down to .026.
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 10-15-2018, 02:36 PM   #3
Pumba
Could that really be the issue ?
The boost on this one is set to 18psi (1.24bar)
The manufacture of the chip says they don't have any boost protection fuel cut installed at all, so the issue gotta be somewhere else..
I have ordered IK20TT Iridium plugs and new cables, hope to get them within the next few days, I'll make sure to check the gap on them then..
Old 10-17-2018, 04:36 PM   #4
ovlov760
ovlov760's Avatar
I've had the exact same experience with my former 850 T5. Altering the gap on my spark plugs fixed it instantly. I'd start with the known 5 cylinder issues you can fix for free.
Old 10-17-2018, 06:58 PM   #5
Pumba
I have just adjusted the gap on the plugs to .026. and sure enough it did indeed help some, but at full boost there's still some slight stuttering.
I'll make sure to check the gap on the new plugs I have ordered before fitting them and hope that and the new cables will fix it..
Thanks a bunch for the hint guys, I'm kinda new to these "newer" cars ;)
Another thing if you lads knows, is the only way to make the engine run richer ECU work ?
The plugs where a lot whiter than I like to see and as far as I know that indicates that it's running to lean..
Old 10-17-2018, 10:48 PM   #6
ovlov760
ovlov760's Avatar
You could even try going to .024 or .025.
Old 10-18-2018, 03:43 AM   #7
Pumba
I'll give it a try ;)
Old 10-18-2018, 07:22 AM   #8
ErikS
FWD!
ErikS's Avatar
I would not use iridium plugs. Copper core NGK B7KRE are what most of us use, colder heat range.
Get a wideband. An 88c tstat will run a little richer.
Who is this tuner?
18 psi on what? TD04?
'95 854 T5M
'15 MB ML350
'15 F150 3.5 Ecoboost
ErikS is offline   Reply With Quote
Old 10-18-2018, 08:58 AM   #9
Pumba
10-4 I'll try that then. (hope I still got time to change the order)
Ok, feeling like a total noob here, but a fuel/air mix controller or ?
Who is this tuner?
it's a reprogrammed BSR chip.
Yes the 15G.. I know it can't take the punishment in the long run and wanna replace it with a 18t or 19t. But that's also a bit of a cash issue..
Old 10-18-2018, 09:25 AM   #10
ovlov760
ovlov760's Avatar
A wideband sensor and gauge will let you know if your air to fuel ratio is safe.
Old 10-18-2018, 10:01 AM   #11
ErikS
FWD!
ErikS's Avatar
You can also just run the OEM Volvo copper plugs, they are fine.
Thermostat - 88C - allows the car to run a little richer under boost.
https://www.amazon.com/Stant-45378-S.../dp/B000C80AFK
BSR is old technology, no way should you be running 18 psi on a 15g, way out of its efficiency range.
Old 10-18-2018, 11:59 AM   #12
Jack
Banned
Jack's Avatar
Who is this tuner?
This
Worn cap/rotor/wires/plugs will do the same. Oem only or you’ll be replacing crap all the time
Also
15g at 18psi pushes a lot of hot air.
Bit of a cash issue you say? Then stop making your car worse. Get out of college and get a job then start to do it right
Old 10-18-2018, 12:55 PM   #13
Sweep
Unnecessary judgement is unnecessary.
Old 10-18-2018, 01:52 PM   #14
ovlov760
ovlov760's Avatar
This
Also
Hopefully he did a stage zero before the mods. These cars are sensitive to worn ignition components when you start modding them.
Old 10-18-2018, 02:57 PM   #15
8DOM8S8AN
Had similar issues with B5204T2 (2.0l version) with 16T #7 angled exhaust flange @ 18-20 psi.
We gapped plugs down to 0.020" (0.50mm) and this cured the issue.
Stage 0 of course!
8DOM8S8AN is offline   Reply With Quote
Old 10-20-2018, 01:27 PM   #16
Pumba
Stage 0 of course!
I'll try to go to .020 thanks for the hint..
I'll try the OEM plugs and the 88C then ;)
What the f** is that for a retarded comment dude ?
I'm bloody 40 years old and are just (as stated) starting on these "new" cars - if you ain't got better to say then don't say anything..
I'm here asking for advise not to be insulted by some fool..
Old 10-20-2018, 01:38 PM   #17
Jack
Banned
Jack's Avatar
Bro bro
We get plenty of 20 some boys here running so much boost you can light glass on fire, with no money or experience
You’re running too much boost. You welcome
Old 10-20-2018, 01:42 PM   #18
Jack
Banned
Jack's Avatar
It’s amazing just how sensitive they are. Runs perfect one day then shet next... pull plugs .. oh yeah replace again after 15k miles or cap rotor every 30k
You realize quickly how much better stock wires are vs say IPd after you pull the wire out of its boot..
Old 10-21-2018, 02:30 PM   #19
8DOM8S8AN
Bro bro
18 psi should be fine?
Also when gapping make sure you don't insert the feeler gauge under the electrode if you are using the good'ole hammer technique. This breaks the ceramic, ask me how I know
Old 10-21-2018, 03:46 PM   #20
ovlov760
ovlov760's Avatar
15-16psi would be more appropriate for a 15G or 16T.
Old 10-26-2018, 05:05 PM   #21
8DOM8S8AN
Yeah, but I think it was stated that the setup they were running was a 15G.
It's pretty high for either turbo, but still one would imagine that power levels will drop before any actual spark issues.
Backpressure will be an issue at these boost levels, but they should only hinder the engines ability to produce power at such boost pressures.
If you are getting misfire at 18psi with a 15g, fix all ignition issues before continuing.
