Old 10-10-2018, 07:30 PM   #1
Marvelous3
Who engineered this?
Marvelous3's Avatar
Default injectors
I think I've got the turbo figured out so now I'm on to injectors. I have a set of orange tops out of an 850 turbo but im thinking ill need something bigger? Plan is 15psi of boost on this 8valve head with big valves and v16 enem cam. I will not be running e85 so no need for 1000cc injectors. What do you all think? Grab some blue injectors from pull a part?
Old 10-10-2018, 07:37 PM   #2
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Big fella I got some bosch greens I wouldn't miss.
IIRC the blues and whites flowed near the same amount at 3 bar so there's that too. (meaning, that would probably be fine if you found one instead of the other)
Old 10-10-2018, 08:07 PM   #3
Marvelous3
Marvelous3's Avatar
^oh yeah? Real greens?
Supposedly the difference in blue and white was solely in the fuel pressure. The injectors themselves flow the same or so they say.
Old 10-10-2018, 08:22 PM   #4
soclosenotnear
What did the turbo choice end up being? Did I miss it?
Old 10-10-2018, 08:43 PM   #5
Marvelous3
Marvelous3's Avatar
50 trim t3/t4
