- Nov 2, 2005
- appleton WI
Travel problem on the back or front?
in back, infront it looks like you have plenty. I wish you could not cut up the car, flares and volvos just dont mix, but i really like where this is going! good job.
Never even thaught about that tbh haha that might be a way to go, il look into it myselfStaying tuned for the finished product, and the side drama lmao.
-edit-
You say you're using Nissan tie-rod ends? The thread size and pitch seems to be the same so that makes sense. At that thought, one could technically use any off-the-shelf heavy duty extended TRE offered for the S-chassis. This has really got me thinking.
I said in a previous post, the back is currently untouched it's not going to stay like that, as it is now it's undricable and any slight turn will have the back tyres scraping the archesin back, infront it looks like you have plenty. I wish you could not cut up the car, flares and volvos just dont mix, but i really like where this is going! good job.
hey dude use land rover defender flares they look much better and fit the cars profile better
Oh forgot to mention...was hoping to get the car up and running and tested today but the weather has been **** so subsided to the garage to play with my bike instead
I'm going to crap my pants if this thing works and drives well. I'm rooting for you,
Not much but still an update,
The drivers side wheel bearing wouldn't tighten up and realised there is a washer missing from the bearing, so having to source one of them
Biggest part being that I have found some steering arms so that they do not need to be welded...
Mk3 vw Pasat tie rods, fit in nicely and have the extra length needed
The Pasat arm I tested was slightly bent off my brothers car so I obviously won't be using that iv ordered 2 more for ?20 each also another Nissan tie rod end which I need which should all be ready to pick up tomorow. Hopefully if there are no more setbacks the front will be finished tomorow
actually, less.This means more turning radius!!
