iHateVolvoPeople
- Feb 1, 2014
- Midwest
delete
I used 2 ft dash 4 with a 90 at the front galley and straight fitting at the turbo. Its maybe 2 or 3 in too long cause it rubs the strut tower. I ordered all my stuff from ebay. Also used rubber line for the drain. And USE THE COOLANT LINES its called thermosyphoning and it prolongs the life of the tubo astronomically if you dont beleive me ask why ever manufacturer uses coolant cooled turbos. The oil lasts longer before breaking down. Still running strong and I just used my car to move all my crap across state. Also run an oil cooler its a necessity, you will have a turbocharged oil heater its best to keep it as cool as possible. Damn near all the parts you need are at the junkyard
Just measure it. My memory is hazy but 99% sure I used 2 ft. Im using a 15g probably going to get a t04e soon as this 15g isnt what I want its just what I had. I can go measure if you need me to
crush it already
Ah, two feet barely works on mine because I have it coming straight out the oil gallery and around the belts up to the turbo. I should of done a 90 first like you're doing and 2ft would of worked easily.
Ya'zzir that'll do
I used -3an for my oil feed line and it works wonders. Oh you could have drilled into the block in the oil feed area and the oil return area on the block. They(b230) all have the spots on the engine from the factory. You could have then used stock feed and return.
