Old 04-18-2012, 01:23 AM   #76
kampman
dunning-krugersquirt
If you're feeling flush, you could get one from the guys at specialtauto.com. They should have a good rebuild in stock.
1984 245T
2006 V50 T5M
Feedback Thread
Old 04-20-2012, 10:17 PM   #77
TestPoint
TestPoint's Avatar
Still researching the replacement fuel distributor.
Pulled the wheels today and found that all the rotors had been turned but are now rusty, new pads all around. All the bleed valves were new but the calipers were rusty. Think I was told that calipers were replaced. I will check on that next week. Replaced the master cylinder as that was next on the PO's list.
Never seen this before but there is no brake fluid to the left rear caliper! Bled the other three normally.
Anyone ever seen this situation before I start tearing apart the brake lines, proportional valve and brake failure device?
Old 04-21-2012, 11:23 AM   #78
M.H. Yount
M.H. Yount's Avatar
Could just be moisture related corrosion in the system has it blocked --- hard to say Tom until you start opening up that line at various places and seeing where you have fluid and where you don't. Good news is that the lines aren't steel - so the corrosion is less likely to have affected them in any significant way.
Old 04-21-2012, 11:31 AM   #79
TestPoint
TestPoint's Avatar
Been raining all morning and since I have run out of garage space this is being done outside. Sun is out now and will get it after lunch. Thought I would start with the proportioning valve.
Old 05-05-2012, 05:59 PM   #80
TestPoint
TestPoint's Avatar
I did get the brake line resolved. The flex hose to the proportioning valve was all gummed up. Replaced the left one and now have the other in hand. You just can't trust a car to sit up 19 years and still run.
In the mean time . . . sent the fuel distributor on an all expense paid vacation to JayTan Ind. in Orange, CA for the full spa treatment. They turned it around in a day and now it doesn't leak . . . but doesn't start either. Still runs on starter fluid.
Ordered the GreenBook fuel injection book off eBay and we will see where we get with that.
Old 06-02-2012, 09:09 PM   #81
TestPoint
TestPoint's Avatar
I have been working on the car doing things that needed to be done but it still doesn't run . . . yet.
Got a big box in today with all the things I needed to finish the front brake rebuild. The car now has newly turned rotors, new calipers, new pads, new flex hoses and new lug nut studs . . . and a new master cylinder. New lug nuts arrive Monday . . . see below.
While the wheels are correct Volvo optional wheels they have created a problem. The 26 year old tires, with about 90% of tread remaining, were 205-65 15 and I ordered and installed the same sized tires. I also found 1/4" spacers behind the wheels that I had intended to do away with but now I know why they were there . . . the tires on these 7" wheels caused the tires to rub the struts. I also found that the lug nuts, with the spacers installed, only had about 3/16" of thread engaged on the studs. That wasn't going to do.
Tried to find longer lug nut studs to solve the issue but ran into the problem that the Volvo has an unique Knurl (yes, a new word to me also) of 0.640" that only comes in one length, 2 5/8", anywhere in this dimension.
I think I have found correct lug nuts that are 0.3" longer than the ones on the car. They are due in Monday and we will see.
I started a new thread on the fuel/start issue here if you would care to learn something about how little I know about Bosch CI fuel systems.
http://forums.turbobricks.com/showthread.php?t=259627
Old 06-12-2012, 07:28 PM   #82
TestPoint
TestPoint's Avatar
Default It's ALIVE!
Got it to run today!
I think the magic solution was to empty the fuel filter, fill it with Seafoam injector clearer, crank it until some should be sitting in the injectors and then wait a day. Filled the filter again and ran that through the injectors while the engine coughed and sputtered.
Earlier I had pulled an injector and it had more of a dribble pattern rather than a spray.
With a finger on the airflow plate got it to run and adjusted the CO screw about 2-3 turns from where it was. Where it was had no relationship to where Volvo left it as the PO's mechanic had obviously tried that as did I.
The engine blew so much water and white smoke out the tail pipe that I thought I must have a head gasket problem. Had visions of a freeze cracked block but that that cleared up. Right side exhaust manifold smoked badly but that was probably from the oil fill pipe above. That cleared up also.
Anyway, it runs and fairly smoothly. Unusually high idle at 900rpm but that is what the GreenBook specifies. The frequency valve is buzzing but I could not hear it. Hearing problem from too much gun range time over too many years. Felt it vibrate.
Now . . . rat chewed coolant overflow tank. Think I will steal the one from the 5.0L 245 until I can get another one here. Except for the hard lines it has a completely new brake system but needs bleeding.
Oil is new, will drain and fill coolant. Anyone know what ATF this thing uses? Didn't even try putting it into drive.
I would like to thank all who contributed to get to this point over the past month, especially John Lane. If you need help on a PRV just search JOHNLANE for excellent advice.
Tomorrow, tomorrow!
Happy! . . . Happy! . . . Happy!
Old 06-12-2012, 07:31 PM   #83
M.H. Yount
M.H. Yount's Avatar
Way to go Tom!
Old 06-13-2012, 12:58 PM   #84
doucheNozzle
doucheNozzle's Avatar
So plans for this car is a nice clean up? DD?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 06-13-2012, 02:21 PM   #85
TestPoint
TestPoint's Avatar
Probably a very limited daily driver. Too many toys.
Old 06-13-2012, 02:22 PM   #86
doucheNozzle
There's no such thing.
Old 06-13-2012, 02:32 PM   #87
NONHOG
equal opportunity car guy
NONHOG's Avatar
Anxious to hear the driving report! Nice going!
Old 06-13-2012, 03:26 PM   #88
TestPoint
TestPoint's Avatar
Too many toys, too much fun!
Got the brake system bled this morning and attempted to fine tune the CO based on the info provided by John Lane. He advises that a O2 sensor voltage of 0.7v is the equivalent to the 1% objective on a CO meter which there are not many around anymore. My sensor will not get that high. Peaks out at 0.61v. Ordered a replacement from Rock Auto closeout for less than $10 shipped. The original replacement interval on the sensor was 25k miles so I don't feel bad about that. Didn't say anything about time period, such as 31 years.
The engine is idling a little high at 1000rpm with the spec being 900 +- 50. That's as low as I can adjust it without detuning the CO screw and driving down the voltage measurement.
Going to change the ATF before moving the car. Nothing shows on the dip stick and that is a little concern. John says F type, AP store says Dextron II. Guess I will give up and look in the as new Coupe owners manual. Yep!, F type.
Off the the ATF store.
Old 06-13-2012, 03:34 PM   #89
Coupe' de Grace
Slowest in the West™
Coupe' de Grace's Avatar
do you still have the anti tamper caps on the adj screws? those do come off
V A F
(1976 265dl/b27/m46 killed in battle, 1991)
(1976 265dl/b27/bw55 bring out ye dead, 2000)
(1980 262c/b28/m46 trebuchet fatality 2014)
1982 244t/b21ft/aw71 'Vicious Chicken of Bristol'
1989 780/b230ft/aw71 'Brave Sir Robin'
Coupe' de Grace is offline   Reply With Quote
Old 06-13-2012, 03:56 PM   #90
TestPoint
TestPoint's Avatar
Yes, the anti tamper devices are still there. They are not like the ones in the Greenbook, no obvious way to remove the caps other than digging them out with something like an awl. I screwed the idle adjust screw all the way in and got the rpm's down from 1100 to 1000. That's all the adjustment discussed in the Greenbook.
Think I have an air leak somewhere? Time for the starter fluid spray?
Old 06-13-2012, 06:03 PM   #91
M.H. Yount
M.H. Yount's Avatar
Take a good look at any of the vacuum connections Tom - at that age I'd expect some rot...
Old 06-13-2012, 06:25 PM   #92
NONHOG
NONHOG's Avatar
Ours use to idle about 1000 rpm. Back when it ran (a few years ago).
Old 06-14-2012, 07:27 PM   #93
TestPoint
TestPoint's Avatar
Default Drove it!
About 5 miles.
Reinstalled the transmission pan and filled, flushed the radiator . . . several times. Still cranks reliably but doesn't seem to have much power. Maybe I am just hesitant to mash on it. Feels like fuel problem.
Transmission shifts nicely! That's a big plus.
At least 2, maybe 3 'whistles'. One, I am sure, is the air filter housing singing, no filter in place. Top/bottom latches missing, big 'O' ring around air flow housing missing.
Got a coolant leak dripping at the rear of the transmission. Nothing wet, that I can see, forward of that. No wet carpet from the heater core.
Spent some time with Hagerity Insurance today. For hobby cars and motorcycles they have really great rates. The thing that makes them so attractive is that they insure the vehicle for collision and comprehensive and then the owner/driver for liability. With only one car they are better than my State Farm agent could come up with. With a second vehicle they cannot be touched since you don't pay for liability coverage again. With 3 hobby cars and an under 3000 mile per year motorcycle they are less than half the price of State Farm. That 3k miles is another point. You have to declare the annual mileage and that affects the rate. Forgot to mention, all this is with declared value and flat bed tow truck coverage.
Anyone with corrections to my understandings or negative comments about claims response please let me know as I may sign up tomorrow.
Anyway, through for the day. Tomorrow, tomorrow.
Old 06-14-2012, 08:04 PM   #94
Coupe' de Grace
leak out back is usually bad heater hose or god forbid some connection to the Y pipe behind the water pump
Old 06-14-2012, 09:03 PM   #95
nel621
Hopefully a heater hose.On my 81 coupe I had to replace the water pump,what a PIA.Replaced everything under there with OEM stuff.Haggerty is a good deal for collector car insurance.I got them for my 79 coupe with agreed value.Way cheaper than adding it to Allstate.No insurance yet on the 81 but will use Haggerty.
Old 06-14-2012, 09:28 PM   #96
TestPoint
TestPoint's Avatar
I will climb under again tomorrow but the heater hose are on the right side of the firewall, a long way from the leak at the back of the transmission without any visual or feel of wet.
Old 06-16-2012, 08:06 PM   #97
TestPoint
TestPoint's Avatar
Default Oh . . . the joy of restoring an old car
One of my greatest fears in buying this car was that sometime in the past 19 years it had frozen and cracked the block or radiator. Doesn't seem to have done that but the heater core is certainly leaking badly. Water is almost spraying out of the AC condensate drip hose. Nothing inside the car so it has got to be the core inside the climate control box. I would swear that the first item on the Volvo assembly line is the climate control box and they built the complete car around that.
That might put the project on hold until I can remove the entire interior. I was going to remove the seats and carpet anyway so I guess I might as well get started. The alternative is to install a shut off valve in the coolant supply line to the core. Probably not going to need heat in Georgia for some time.
I had almost rather pull the engine than the heater core. Done that about 30+ years ago on a '71 145 when I bent a little easier . . . and weighed a little less.
Throttle cable and other connections to the throttle plates were corroded and difficult to move. Two-three hours of pleasant entertainment and everything moves a lot easier.
While dealing with the throttle cable issue tried cleaning up the exterior surfaces of all the aluminum parts. Does someone have experience cleaning up 30 year old corroded aluminum? This is not salt corrosion but just aluminum oxide. Sand blasting? Soda blasting? Always wanted a blasting cabinet.
Off to the WWW for a heater core.
Old 06-16-2012, 08:32 PM   #98
nel621
If you're going to remove the heater core you may want to consider changing the blower motor while you're at it.I know it may work now but it is also 30 years old too.It is also another treasure hunt.Buried crap!
Old 06-16-2012, 08:38 PM   #99
TestPoint
TestPoint's Avatar
Replaced one of those also. You bet is will run on the bench perfectly before going back together. It does run fine at the moment but that is before being sprayed with coolant.
Old 06-16-2012, 08:39 PM   #100
JohnLane
You will remember the heater core in the 145 fondly after doing this one!
Be sure to do a heater blower motor, resistor and switch while you're at it. This is a task that is easier with the windshield pulled. Verify that you can still source that window as it may be special for the coupe.....
Hows she running now?
