Old 04-30-2018, 11:10 PM   #1201
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Ah, I follow you. Potato moment as I left my thinking hat at the job so I knew where it was tomorrow, ha.
Old 05-01-2018, 01:40 PM   #1202
I'm really not sure I'll be able to remove/replace the transmission with the motor installed. I've been putting it on and off currently with no flywheel/clutch/pressure plate, not even a pilot bearing, So it really needs just an inch or slightly less clearance before the input shaft goes in the hole and it slides forward. The whole trans is pretty long, and the engine doesn't lean back very much (perhaps I should look at why?) - I'm not thinking it would work if I had to slide it out several inches to clear a clutch.
Old 05-01-2018, 06:02 PM   #1203
cosbySweater
cosbySweater's Avatar
If you loosen the engine mounts you can tilt the engine back pretty far
Old 05-01-2018, 11:04 PM   #1204
Texas240
Prius Owner
Texas240's Avatar
and drop the front cross member an inch or two.
93 245 LS Engine Swap Project
Old 05-02-2018, 12:32 AM   #1205
cosbySweater
I never had to do that. But I'm sure it would help. With the 6speed I loosened the mounts. With the 80e I don't touch anything
Old 05-02-2018, 09:17 AM   #1206
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
This is the exact Poly mount that will be available to purchase with the CD009 adapter I make, it line up perfectly with the trans mounting point and is cheaper than the stock "axial" cd009 mount. I just ordered a batch of 10 of them so they can be shipped together!
It really is a big transmission where it split in two right at the end. I hope the fit in a 7/9 will be a bit forgiving.
94 944T - 16v turbo - 12,14@122
Lm7 5.3, S475, Ms3Pro, 4l80e - 10,36 @ 134 / 6,70 @ 107
www.deeworks.ca
Need T5 Adapter? T5 Speedometer Plug? Gm Torque Converter Adapter? Freeze plug retainer? HE351 solenoid plug? Pm me!
Roger-Dee is offline   Reply With Quote
Old 05-02-2018, 09:05 PM   #1207
Texas240
Prius Owner
Texas240's Avatar
Im anticipating this to pull out my 4l60e to change out the torque converter.
Old 05-04-2018, 09:44 PM   #1208
After weeks of CAD design and hours of exacting machine work, here's my super intricate transmission mount:
Yeah, it's a solid chunk of metal (2X.25) with 3 holes drilled in it. One bolt goes through the T5 mount and the chunk of metal into the trans. The next one (middle bolt) just goes through the chunk into the trans, and the last one just bolts the T5 mount to the chunk.
The whole T5 mount isn't shown, just the top part.
I could have found a mount that would fit to the CD009 directly, but it wouldn't have centered properly on the T5 crossmember. For better or worse, the T5 is off center, and it just happens to sort of match up to the CD009 on one side.
Easy, cheesy, on to other things.
Old 05-05-2018, 07:19 AM   #1209
DET17
Reformed SAABaholic
Adapto-magic! TB loves simple solutions......
BTW, M.H.Yount sectioned part of his 240 crossmember out and modified it to "bolt in" so he could pull his T5 with engine in situ, for clutch work. I'm sure he has photo records of those changes.
Old 05-05-2018, 08:20 AM   #1210
The T5 was easy to pull. Just take off the 4 bolts holding it to the adapter plate, and pull it back. Cross member, shifter, driveshaft removed, of course. But no struggling with those bell housing bolts.
It remains to be seen how easily the CD009 comes out. It's got a lot less wiggle room.
Old 05-05-2018, 12:49 PM   #1211
M.H. Yount
M.H. Yount's Avatar
Getting tranny out has, in my experience, always been a piece of cake. Getting it back in -- especially if the disc/pressure plate has been monkeyed with --- not so much.
DET - engine x-mem cut was primarily so I could, by myself, easily pull engine/tranny combo for fab purposes during the swap. With tight points around clutch arm, exh manis and oil pan -- needed some clearance somewhere to manage the hoist/angles alone. I think I had it in/out 10-11 times during clean up and fab. If I had only clutch work to do at this point - I'd likely just drop tranny and do it from the bottom.
Old 05-08-2018, 03:02 AM   #1212
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Awesome..!!! May I have the drawings?
Old 05-08-2018, 01:29 PM   #1213
Heh, I didn't even measure anything, I just eyeballed it.
Trans came out again yesterday, waiting for the new top mount shifter.
I'm going to pluck the engine out tonight and start tweaking (bashing) the passenger inner fender, some small love taps on the right header (motor mount clearance) and the crossover tube (sway bar clearance).
I pondered that downpipe fitment a little bit, and just decided that all it needs is a less bulky connecter between the upper and lower sections. It all fits quite nicely, there's just a v-band clamp in an awkward spot. I'm thinking all I need to do is cut off the v-bands and use a band clamp:
That way it removes almost all the bulk and size of the v-band clamp, without me needing to heavily rework anything. I might just need to weld a small section of 3" tubing on to fine tune the fit.
Old 05-21-2018, 12:53 PM   #1214
After a week or two if inaction on this, I spent a while yesterday. Pulled the motor out and spent a while bumping, yanking, thumping, bashing, grinding, bending. Fixing all the small fitment issues. Then stuck the motor back in. It all looks the same, but now nothing is touching that shouldn't be.
Still waiting on the top mount shifter to arrive.
Futzed around with various power steering lines I had laying around (240, 740, 940) and while they all screw right into the GM steering pump, the clearance between the bracketry and the pulley at the engine is very exacting. After a while I decided to just skip trying to make something work with the 3 pressure lines I had and got a couple of adapters - GM Corvette (it's snug) to 6AN adapter, and an M14X1.5 banjo to 6AN adapter, and a 6AN hose. Won't look cheesy, no stacked adapters, everything fits straight on, nice generic hose - just two female 6AN fittings on each end.
Yeah, that's all I have to show for the last couple of weeks.
Old 05-21-2018, 11:51 PM   #1215
LC4CARL
Aero challenged
LC4CARL's Avatar
And months from now you’ll catch glimpse of some detail you nailed and smile.
Life begins at 10PSI.
Old 05-22-2018, 09:26 AM   #1216
poulrais
poulrais's Avatar
Where did you order the top mount shifter?
1990, Volvo 740 16v +T
Old 05-22-2018, 10:22 AM   #1217
CBF Performance.
http://cbfperformance.net/?~~id=70985258&~~mode=product
Even the shortest ones that hang off the rear are not going to fit very well into a 240. Even with the engine scooted an inch and a quarter forward from where the STS mounts placed it.
This will be a bit too far forward, might need to trim the shifter hole slightly, and use the extension on the lever to move it a couple of inches to the back.
Old 05-22-2018, 10:46 PM   #1218
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I am watching this Nissan trans adventure as an alternative to the t5 planned for mine.
Old 05-29-2018, 08:51 AM   #1219
poulrais
poulrais's Avatar
Did you receive your shifter?
Old 05-29-2018, 09:36 AM   #1220
Nope. I don't want to be a pest, but I'm going to ask for a rough date. It's been a month so far. No real word about lead times when I ordered it.
Old 05-29-2018, 10:03 AM   #1221
poulrais
poulrais's Avatar
Was it supposed to be in stock? If so, one month is pretty long to receive an item in stock imo...
Old 05-29-2018, 10:15 AM   #1222
He didn't say one way or another.
Old 06-05-2018, 09:38 AM   #1223
Still waiting on that shifter, no response to email.
Old 06-05-2018, 02:45 PM   #1224
poulrais
poulrais's Avatar
This sucks balls big time. I just so damn hate these suppliers who take your hard earned money and don't deliver the goods. At least give the customers some feedback if there is a problem!
Did you pay with Paypal?
Old 06-05-2018, 02:54 PM   #1225
Yeah, on 4/25. I'm not going to raise a stink at this point. I'm just waiting patiently. They're not Amazon.com. It would just be nice if they'd give me a hint about when.
I don't think there are any other options at this point for a top mount shifter.
