Old 08-28-2018, 06:13 PM   #1
humbo
Default 1979 242 refrigerant capacity
I'm recharging my 1979 242 A/C system and can't find the refrigerant capacity. The charts I've been able to locate only go back to 1985 and they say 46 oz of R12 and 10 oz of mineral oil. Would appreciate info on the '79 capacities. It is a factory a/c system.
Thanks
Jim
humbo is offline   Reply With Quote
Old 08-28-2018, 07:18 PM   #2
The greenbook says 2.9 lbs. of R12 which is 46.4 oz. and 300cm³ (.64 US pint or 10.24 oz.) of oil although it says the compressor should come filled with the proper amount and to make a dipstick to check it.
Old 09-04-2018, 07:40 PM   #3
humbo
This car had some 134 put into somewhere along the line. We have done a pressure check and it is perfect. Question is: How do I flush all the old 134 that might still be lurking in the system, including the compressor,out of the system? Thanks
Jim
Old 09-04-2018, 08:43 PM   #4
iHateVolvoPeople
Jim
How to flush AC compressor
Use AC flush in all of the lines to clear them out. Can't really flush past the TXC afaik. Replace R/D.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
Past:
80' 242gt m46
88' 245T m47
92' 945T AW71
94' 945T AW71
Old 09-06-2018, 03:55 PM   #5
A tough rowing ho
I bet I can get several cases in the trunk.
