Old 10-03-2018, 06:19 AM   #1
Bom
Default How much boost can I take?
Car is 940SE with 19T turbo+new exhaust+ipd cam. I run 10 lbs at the moment. Curious how much boost I can increase without tuning ECU.
Thanks
Bom is offline   Reply With Quote
Old 10-03-2018, 06:31 AM   #2
soclosenotnear
Stock injectors?
Old 10-03-2018, 07:01 AM   #3
A tough rowing ho
Turn it up until head gasket blows then turn it back one turn.
Old 10-03-2018, 07:20 AM   #4
Vincent Gagnon
Vincent Gagnon's Avatar
This, upload pictures please.
Old 10-03-2018, 07:30 AM   #5
Sjeng
Sjeng's Avatar
Unfortunately he will hit LH fuelcut before this happens. Probably at under 15psi.
Old 10-03-2018, 10:14 AM   #6
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
take all the boost. All of it.
Megasquirt Tuning!
Old 10-03-2018, 10:14 AM   #7
linuxman51
linuxman51's Avatar
oooh and don't fix the gasket either, that's cheating
Old 10-03-2018, 10:24 AM   #8
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Head gaskets work like a blow off valve.
Hello My Glorious!
Old 10-03-2018, 11:26 AM   #9
oldschoolvolvo
oldschoolvolvo's Avatar
Do you have a wideband oxygen sensor?
-Mike
1998 V70 T5
|Feedback|
Old 10-03-2018, 11:29 AM   #10
CNA stock support?
Old 10-03-2018, 12:44 PM   #11
240240
Solely ruined TB
240240's Avatar
As much boost as you want.
Old 10-03-2018, 01:39 PM   #12
When you find the answer please report back.
Old 10-03-2018, 02:37 PM   #13
*like*
Old 10-03-2018, 02:38 PM   #14
Jack
junkman
Jack's Avatar
on 87 I crank it up to 17psi
on 91 i crank it up to 22psi
Old 10-03-2018, 03:09 PM   #15
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
28psi
B5.5 passat wagon, low af sexier than most wagons here.
Old 10-03-2018, 03:16 PM   #16
Mbeas96
Mbeas96's Avatar
Turn it up till you hear bad noises, then turn down a tad till the bad noises go away. That, sir, is how many psi's you can have
Old 10-03-2018, 03:20 PM   #17
This thread is my second favorite right behind;
'Say does anybody happen to have a complete set of NOS 242 Turbo side trim just laying around that they aren't using and want to get rid of?'
Old 10-03-2018, 07:21 PM   #18
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
Damn It. Beat me there.
No boost. No boost for you.
2013 Audi Q5
Sold- 2006 V70R
PeaceEngineered is offline   Reply With Quote
Old 10-03-2018, 07:33 PM   #19
VolvoGuy123
VolvoGuy123's Avatar
Thanks
assuming it is a healthy motor and all maintenance is up to date, blah blah... you'll need a set of "big green R" injectors and a 3" AMM at the very least. Then I wouldn't go past 18-20psi until you get some other proper supporting mods (IC, Wideband, etc) and I would also go full syth (fluid/filter/gasket) service in the transmission and perform the "accumulator mod!"
VolvoGuy123 is offline   Reply With Quote
Old 10-03-2018, 08:04 PM   #20
TurboDenny
Why am I here?
Assuming you can get the butt plug in tight enough, I bet you're safe for a couple psi before it hurts.
Instagram: @itstotesdenny
Old 10-03-2018, 08:22 PM   #21
Mbeas96
Mbeas96's Avatar
Ermmm...20 psi might not be so good with the stock IC...
Old 10-04-2018, 09:39 AM   #22
Bom
Injectors are stock. From what car is the big green R injector and 3”AMM?
Old 10-04-2018, 09:49 AM   #23
http://forums.turbobricks.com/newthr...newthread&f=14
Old 10-04-2018, 10:34 AM   #24
Vincent Gagnon
Please, for now, leave the boost alone.
Old 10-11-2018, 11:26 PM   #25
Jack
junkman
Jack's Avatar
Get out Vincent. This is how legends are born
