Old 10-10-2018, 02:48 PM   #1
zdriver123
zdriver123's Avatar
Default Turbo Gaskets
Hey all,
It's been a while since I've played with a Volvo, and never with a Turbo. I'm just swapping a bad 13C with a good 13C and have a couple questions. I'm trying to find a manifold to Turbo gasket, and I would assume a downpipe gasket? I'm doing this for a friend, and am wanting everything to go smoothly. I tried looking on IPD and came up with nothing.
I'm guessing that's on me, Can anyone lend a hand?
zdriver123 is offline   Reply With Quote
Old 10-10-2018, 02:51 PM   #2
quillc
yv1a.com
quillc's Avatar
The Volvo manifolds have that funky step in it. They don't use a gasket. Same thing on the outlet, it is just flanged.
Chris
www.yv1a.com
Old 10-10-2018, 02:52 PM   #3
oldschoolvolvo
oldschoolvolvo's Avatar
You can use 8642450 for the turbo to manifold gasket.
No gasket is used on the conical turbo to downpipe connection.
-Mike
1998 V70 T5
|Feedback|
Old 10-11-2018, 02:02 AM   #4
A tough rowing ho
My machinist recommended engine paint between the turbo and manifold, it seems to have helped.
Old 10-11-2018, 02:35 AM   #5
PhysSDK2
Hmm Id be concerned about the O2 sensor depending on the paint. I think ceramic paint there would foul the sensor. I guess you could run a bad one for some break in then put a good one back in.
PhysSDK2 is offline   Reply With Quote
Old 10-11-2018, 05:24 AM   #6
thismachine13
Went to Hobby Lobby and bought a small piece of copper (4”x6”?) for $7 and made my own.
Old 10-11-2018, 08:00 AM   #7
A tough rowing ho
I waited for it to dry, did not affect my wideband.
Old 10-11-2018, 12:06 PM   #8
woodenpudden
lacks goats
woodenpudden's Avatar
Correct.
Adding a gasket between turbo and stepped manifold outlet can cause a wee exhaust leak.
Helped with what? Stock turbo + stock/unaltered manifold + tight nutz should result in an adequate seal.
Originally Posted by DMFWallace View Post
Flunt delivers!
woodenpudden is offline   Reply With Quote
Old 10-11-2018, 12:55 PM   #9
oldschoolvolvo
I haven't had issues using the 8642450 gasket with a 13C and a 16T on a 90+ manifold. FWIW, it is spec'd for the 5cyl manifolds with the step.
https://www.fcpeuro.com/products/vol...642450#fitment
Old 10-11-2018, 02:25 PM   #10
woodenpudden
lacks goats
I can dig it, didn't look up the part number before to see
Old 10-11-2018, 02:29 PM   #11
Jack
junkman
Jack's Avatar
Thats what I run on 5 and 4 cylinders
Dont bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 10-11-2018, 08:55 PM   #12
A tough rowing ho
Correct.
Mine is machined flat for Chinese turbo with a metal gasket in between, it helped with minor weep/leak.
