Old 11-15-2009, 06:22 PM   #1
morganpartee
Default Auto to Ford T5 swap Q's
Alright guys, AW70 took a crap, and I got offered a ford T5 for 250.
So, the choice to me is fairly obvious.
I guess my biggest question (and I have read the write up) is, what parts am I forgetting?
I know I'll need a flywheel, clutch, pedal box, and some nature (Hydraulic or cable?) of connection between the two. Also, I'll need an adapter kit, and a bellhousing from a manual tranny.
Now, I need parts suppliers, suggestions, experience, etc. I've never had anything to do with manual boxes, aside from drive a couple, and I'm hooked. Advice is always good too!
Thanks.
Finally back in the 740 game.
morganpartee is offline   Reply With Quote
Old 11-15-2009, 06:28 PM   #2
TerribleOne
ZoomZoom
TerribleOne's Avatar
I can get you a bellhousing for a manual transmission..
What are you using for a driveshaft?
I've done the swap.. but only on a 240. So I can offer little advice in terms of driveshaft length, shifter fittment etc. I reccomend rebuilding it while it's outta the car before you even start. It's pretty easy and it gives you a chance to make sure it hasn't been trashed.. You dont really know until you get the tail housings off those T-5's and get the top cover off.. And if you're gonna go that far, you may as well press some new bearings on, and replace the wearable items inside.
75 242GL - LS turbo, 4L80E, narrowed four linked 9"
89 244DL- Mazda 2.3 MZR, S366, 5R55E on Electromotive TecGT with PCS paddle shifters
94 945- Beater
93 965- For sale
91 940SE- Roller, for sale
TerribleOne is offline   Reply With Quote
Old 11-15-2009, 06:53 PM   #3
morganpartee
I have no idea what I'll do for the driveshaft. I'm really just now begining to think about it. I was planning on rebuilding it while Its out of the car, just for peace of mind. The guy claims he uses it daily still, and it shifts and sounds fine.
My biggest concern is the clutch cable/pedal/bearing setup. What'd you do for that?
Old 11-24-2009, 05:49 PM   #4
ADent
Lots of info out there. But here one place with photos: http://www.v-performance.com/products/transmission.html .
98 S70 5sp - Kid's car
96 854GLT - Daily driver
88 745GLE 5.0 - (5.0/T5)
ADent is offline   Reply With Quote
