Old 05-21-2010, 09:50 AM   #1
black 940
black 940's Avatar
Default 5 speeed
I know this has been discussed, but can someone advise me on a direct swap in 5 speed trans. I would prefer not to do many modifications this is for a '93 945 turbo. Is an M46 going to work? If it does will the flywheel have the crank sensor ring to pick up the sensor.
-05 V70R M66
-93 945 Turbo, stock 15 G. Running great with a '95 Turbo engine, Sold and I know it will be missed, favorite one so far!
-94 940 N/A, bilstein struts and shocks, stock other than that. 207,000 miles and rising quickly.
SOLD and missed already
-96 965, stock, Sold
-86 944 Turbo, Tem, fun, good weather car.
black 940 is offline   Reply With Quote
Old 05-21-2010, 09:55 AM   #2
CaffeineSam
The M46 is a 4-speed + overdrive, but it would work. You need to replace the cross-member and the driving shaft. There's the M47 that is a true 5-speed, although reputed to be a little weaker.
For flywheel questions, wait until someone else picks up...
CaffeineSam is offline   Reply With Quote
Old 05-22-2010, 04:55 AM   #3
ADent
You need the manual flywheel that matches your EFI - ie if that is Bosch LH 2.4, then you need a 2.4 manual flywheel.
The hole count on the new flywheel should match what the car has now.
98 S70 5sp - Kid's car
96 854GLT - Daily driver
88 745GLE 5.0 - (5.0/T5)
ADent is offline   Reply With Quote
Old 05-23-2010, 11:53 AM   #4
black 940
black 940's Avatar
Any suggestions on where to find a flywheel. I have a '93 945 Turbo, unknown what electronics.
Old 05-23-2010, 11:58 AM   #5
nextproject
you have LH2.4. Start hitting up the classifieds, post an ad in the want ads section, the guys on here are pretty damn good about getting you what you need in a short period of time. Usually a matter of hours! Go with the M46, get the proper driveshaft and crossmember, and get the electronics for the overdrive as well, if you want to skip the electronics then just get the M47 and its corresponding driveshaft. The flywheel will be the same LH2.4 version no matter which transmission you use.
nextproject is offline   Reply With Quote
Old 05-23-2010, 12:00 PM   #6
jimmy1000000
Do a search I see them for sale especially in for sale. You could also do a post in wanted if you don't feel like going to the JY.
jimmy1000000 is offline   Reply With Quote
Old 05-23-2010, 04:42 PM   #7
black 940
black 940's Avatar
A few more questions. I have found several 5 spd 240s, I am assuming I will need a trans from a 740 as well as the drive shaft from a 740 or is there a 240 year etc. to look out for? What year 740 would I look for?
Old 05-23-2010, 05:51 PM   #8
jimmy1000000
5 speed Transmission will work. m47 true 5 speed. m46 4 speed with overdrive you will see the switch on shifter for the overdrive.
A drive shaft from a 240 may not work for you I guess it depends on how much you want fab or have fabbed. I would grab one because its the correct kind of shaft. The career barring may not end up in the correct spot. Grab a couple of guibo's while your at it.
I just shortened the front side shaft out of a 700 series wagon to use in my 240 with a m47 5 speed.
Old 05-25-2010, 05:21 PM   #9
Aussie Volvo
Hi
You will need a 700 or 900 series M46/47 because the shifter is different to the 240 version the boxes are the same
You will also need a
LH 2.4 flywheel
manual pedal box and fluid lines and bits and peices from under the dash
the right 700/900 series tailsharft to suit the box you are running
and crossmember to suit
George
George
Daily driver
15 Mitsubishi triton
Gone but not forgotten personal import 98 S70 T5
My Old car Soon to be restored and Modified again see link below
http://www.cardomain.com/ride/2151948
Aussie Volvo is offline   Reply With Quote
Old 05-26-2010, 11:58 AM   #10
TR Conn
TR Conn's Avatar
I have some of what you may need is listed on ebay now. I've listed it here in the for sale section, had no interest, so it went to ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...STRK:MESELX:IT
TR Conn is offline   Reply With Quote
Old 05-27-2010, 05:53 PM   #11
clarda
clarda's Avatar
is the m46 and the m47 crossmembers the same?
clarda is offline   Reply With Quote
