Old 07-18-2006, 10:18 AM   #1
outofworkjoe
outofworkjoe's Avatar
Default The best oil for 940 turbo?
Ive been looking around at many oils What type do you use and why? Allso why is it best to use mann/volvo filters?
outofworkjoe is offline   Reply With Quote
Old 07-18-2006, 10:25 AM   #2
impulse922
It is best to use them because they are made better than pretty much any filter out there for your car.
-Matt
'90 780 and '03 s60 T5M
impulse922 is offline   Reply With Quote
Old 07-18-2006, 10:36 AM   #3
Bob Kraushaar
Mann filters do a superior job. According to those who have cut open filters to compare, they have more filtering material which means more surface area. The material is also supposed to be finer than the norm. This translates into less particulates passing through the filter but adequate flow being maintained.
I use Mobil 1, 10W-30 or 10W-40, whichever Sam's Club has in stock that week. I changed over from dino oil at about 100K with no ill effects (there are those who worry about leaks showing up after a switch but I did not experience any). The car ('94 945T) currently has 225k and is still going fine. No smoke. I change the oil once or twice a year (10-15K). I recently had the head off (200K) to replace the head gasket and the factory hone marks were readily apparent on the cylinder walls. To the best of my knowledge, early in this car's life (I got it at about 45K), it went over 40K without an oil change. Tough little b*stard.
Bob Kraushaar is offline   Reply With Quote
Old 07-18-2006, 10:41 AM   #4
740TurboPerformance
740TurboPerformance's Avatar
For a decent recommendation it'd also be nice to know the mileage, condition of the engine, if it consumes any oil, makes any noise etc, also the climate driven . . . .
Most people here run Castrol, Mobil1, Valvoline and a few run Amsoil. Just avoid crap like Pennzoil and only go with Mann/Volvo filters since they are pretty much the best.
Videos of my 740 @252K:
745T Aftermarket Exhaust
Driving The 745T w/9PSI
Past and Present - 1987 745T - 1987 740T - 1988 745T -
1994 960 - 1994 850T - 1997 S90
855 T5 w/ Carsound/Magnaflow high flow exhaust,
sedan rear sway added, Eagle RSA's.
740TurboPerformance is offline   Reply With Quote
Old 07-18-2006, 10:47 AM   #5
m4ff3w
m4ff3w's Avatar
What are the prices on the Mann/Volvo filters? Dealer only item?
m4ff3w is offline   Reply With Quote
Old 07-18-2006, 10:54 AM   #6
Justin Volvo
Slow Rider
Justin Volvo's Avatar
theyre 3 or 4 bucks apiece, mailorder. Save a few bucks on a case of 10.
http://www.fcpgroton.com/volvo700tuneup.htm
Justin Volvo is offline   Reply With Quote
Old 07-18-2006, 11:50 AM   #7
RollingThunder
The Stig
Thumbs up
+1 for Mobil 1 and Mann filters.
I changed over my 1993 B200FT from dino to Mobil 1 at 125k - no leaks. Usual procedure - engine flush, filter and cheap synth for 2k miles, then another filter and Mobil 1. Did the same with my B230FK at 94k miles - no problems there either.
RT
current:
'98 940 LPT + M90 Torslanda estate
previous:
'98 V70R AWD
'98 V70R on LPG
'96 855R auto
'91 944 2.0 SE turbo auto
'92 964 3.0 24v auto
'92 965 3.0 24v auto
'92 944 2.3 8v GL auto (x2)
'93 945 2.0 Turbo GLE manual
'94 855 2.0 20v GLT auto
'97 944 2.3 LPT Classic auto
RollingThunder is offline   Reply With Quote
Old 07-18-2006, 01:55 PM   #8
dalek
Benchracer Tribe
dalek's Avatar
My local supplier seems to have the Manns for $4.7 apiece in his website, http://catalog.eautopartscatalog.com...art=Oil+Filter, but he has sold them to me for around $3 when I drove there.
About Oil, I am using right now Mobil 1 but am planning on going to Rotela synthetic and see what happens.
Feedback!
Old 07-18-2006, 05:18 PM   #9
ADent
Are there any 15W40 synthetics?
Seems like that would be a better choice than 10W30 - as long as it stays above 0F.
Mobil 1 is available in 15W50 - 20W50 was an option on B21Fs (per our 1979 owners manual).
ADent is offline   Reply With Quote
Old 07-18-2006, 08:27 PM   #10
slowmotion
slowmotion's Avatar
Mann filters are simply better filters and they also have a valve in them... Which means oil stays in there when the car is off. If you use a generic filter you'll notice your oil light comes on when you start your car (even though it only stays on for a second, it strikes fear into your heart)..
That's enough reason for me. Other people will be able to give you a better description of what the valve really does; but I just know it works and there is no reason not to get Mann when they are that cheap.
slowmotion is offline   Reply With Quote
Old 07-18-2006, 08:42 PM   #11
SteveMD
Membro
SteveMD's Avatar
After much reading online, Shell Rotella Synthetic 5w-40, at Walmart for about $15. gallon.
Mann filters. Purolator if Mann not available.
Old 07-18-2006, 09:23 PM   #12
Mr. V
Mr. V's Avatar
Mann oil filters, and the cheapest dino I can get with rebate coupons: usually Chevron or Shell (decent stuff, actually), @ $.49 or $.59 each after rebate.
I change about every 2000 miles.
Old 07-27-2006, 02:12 AM   #13
BLOODstorm
What abou t synthetics? (ie. slick 50)
BLOODstorm is offline   Reply With Quote
Old 07-27-2006, 02:14 AM   #14
fengler
fengler's Avatar
napa filters and mobil one if you can afford it.
Current-2006 Toyota Highlander Hybrid (190k)
Current-1967 Volvo P1800
Fengler would totally smash.
Originally Posted by regina745ti View Post
lext nevel hengler maneuver
Originally Posted by resa850
Nick: I love you.
Originally Posted by CaptainLeah View Post
I saw fengler was the OP and I knew it was going to be gold.
"Without music, life would be a mistake." - Nietzsche
fengler is offline   Reply With Quote
Old 07-27-2006, 02:16 AM   #15
fengler
fengler's Avatar
+1 on shell rotella, this oil is also widely used in hipo motorcycles as a motorcycle specific oil subsitution.
