Old 11-17-2006, 12:42 AM   #1
Unregistered
Guest
Default 740 air intake
Just got a 740 turbo. It's an 87 so to my understanding the thermostat is in the airbox. The flap in the airbox is broken and i have seen air intake kits for sale on a site. So what would i do with the thermostat?
Thanks
Old 11-17-2006, 01:07 AM   #2
marchul
quarter ricer
marchul's Avatar
Throw it away.
'82 242t+ic Miss it...
'05 Mazda6 3.0 MTX Oh yeah...
Originally Posted by adrianpike View Post
uhhhh this is Turbobricks. $4k is like 95% of the entire board's car **** budget added together for a year.
marchul is offline   Reply With Quote
Old 11-17-2006, 01:26 AM   #3
sweetswede
sweetswede's Avatar
you don't want to add heated air to your intake charge, ditch it, don't look back.
sweetswede is offline   Reply With Quote
Old 11-17-2006, 02:30 AM   #4
240Psycho
still trying
240Psycho's Avatar
The Thermastat was installed for cars in cold weather climates (not sure on the temp it opens) im also 50% sure that its a emissions required thing, cause even turbo cars got them and it seems kind of a waste of plastic and metal.
Remove the metal hose and the thermastat, then either glue or screw the flap shut so only "cold" air enters the Air box,
GL
..::VFBG::..
Kyle with a
'91 244 2.5L 16V turbo
00 S70 T5
81 242 T
79 242 GT
240Psycho is offline   Reply With Quote
Old 11-17-2006, 03:32 AM   #5
Tom Wiley
my N/A has one. or had one
Tom Wiley is offline   Reply With Quote
Old 11-17-2006, 04:26 AM   #6
ADent
I have been driving for about 15 years on several Volvos with/out the preheat. Worked fine at -20F in Chicago.
On my current ride it went bad and I had massive ping on anything more than idle - before I could pull it out. Limped home and it seems OK now with it removed. Wonder how many miles I took off AMM, turbo, and other components.
Art
87 745T - no thermostat, no preheat hose
84 245DL - no thermostat, no preheat hose
ADent is offline   Reply With Quote
Old 11-17-2006, 12:01 PM   #7
Unregistered
Guest
sweet. Thanks everyone. I'll remove the thermostat as soon as i get it home. The flap wa actually glued open but the glue came off. Has anybody had any good experience w/ an aftermarket intake? I was looking at getting this Ultra-Flo Intake.
http://www.eurosporttuning.ca/Mercha...Code=VL-740-en
Theres also an intake i've seen on Evil bay...but im a lil worried about getting the e-bay one. Thanks again
Old 11-17-2006, 12:25 PM   #8
Tick
ASSFACEHOLE
Tick's Avatar
There are writeups floating around. But the way I've got mine setup is I capped off the hot air pickup side with a paint can lid. Then cut the thermo flapper out of the bottom with a keyhole saw lined up to put a 3" radiator pipe through the knockout directly under and in front of the box.. It passes cali emissions testing w/ flying colors.
Tick is offline   Reply With Quote
Old 11-17-2006, 12:28 PM   #9
765tiME
765tiME's Avatar
You can remove the box altogether and put a cone filter on just before the AMM, then just rig a support for it.
765tiME is offline   Reply With Quote
