Old 02-08-2019, 11:58 PM   #1
PNW760
Default Heat stops blowing warm after idling too long
Lately now, if my car sits longer than 30 seconds-1 min, it starts to blow cold air and heat seems to not work at all.
Also it seems to be that the fan turns on and sounds like itís going crazy any time it sits longer than 30secs to a minute.
Car doesnít overheat and no condensation that would normally occur from a bad heater core so Iím really not sure what it would be...
I'm just here for the soccer moms and grandmas
PNW760 is offline   Reply With Quote
Old 02-09-2019, 02:53 AM   #2
Shifted
Midnight Watch
Shifted's Avatar
You need a new thermostat.
He built my Bose 901s all by himself...
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"The mountain streams that rush on by/Show the fish a-jumpin' and reflect the open sky/The fresh clean smell of the pines/Symbol of unchanging times/All around this sacred land/Strangely, though, I've found my way/Right here I'm a-gonna stay/In this land" Tom Johnston/Doobie Brothers "Ukiah"
Lifeboat for the plankwalkers/otherwise disenfranchised.
Shifted is offline   Reply With Quote
Old 02-09-2019, 10:15 AM   #3
Mbeas96
Mbeas96's Avatar
Either that or you are low on coolant
Old 02-09-2019, 12:10 PM   #4
petiww
petiww's Avatar
Coolant slowly circulates through the heater core while it is idling, thus cool air can quickly cool it back. Either the heater valve cant open fully, or there is blockage or limescale in the heater circuit.
Whats up with the fan? Which fan? Heater fan or e-fan at the radiator?
1980 Brown 244 GL
Old 02-09-2019, 12:26 PM   #5
sbabbs
sbabbs's Avatar
Do you still have that heater control valve under the hood that is plastic and likes to blow up? I'd ditch that.. It's right behind the head hooked into the heater hoses. Controlled by a vacuum line.
On my 91 740 has that one flapper that opens cold air from outside and it is electric and it was stuck open. I had to swap that for one that worked, you know closes the cold air from outside. Other then that vacuum operates the other flappers and that heater control valve maybe you got vacuum leak and stuff ain't working like it should at idle..
Old 02-09-2019, 03:06 PM   #6
PNW760
Wouldnít a bad thermostat cause a temp drop in the in car temp gauge?
Old 02-09-2019, 03:09 PM   #7
PNW760
I just checked and I am a little low, the car doesnít overheat though so I donít think itís quite that low. But would having low coolant simply be enough to do this?
Also if I do replace my thermostat, I might as well do a coolant flush while Iím there?
Old 02-09-2019, 03:12 PM   #8
PNW760
Hey sbabbs, I still have the heater control valve, if I were to ditch it, how would I do that? Just loop the lines? Or is there a special procedure? Iíve heard these can blow up from time to time and considering the 940 has 324k miles, itís either a replaced unit or a ticking time bomb
Old 02-09-2019, 03:59 PM   #9
sbabbs
sbabbs's Avatar
Take it out and one of the hoses and just attach the other hose that also went to valve to the firewall instead. Or put connector pipe where the valve was. That valve blew up on that 940 wagon I bought the other day, blew head gasket cause I kept driving..
Old 02-09-2019, 06:28 PM   #10
alschnertz
Enough already!
alschnertz's Avatar
Old 02-09-2019, 11:00 PM   #11
On a 7/9 series if you don't have any coolant in the overflow bottle, you may be low enough on coolant that the heater core does not get a steady flow of coolant. You have to be about 1/2 gallon low to cause that problem.
Old 02-11-2019, 05:49 PM   #12
PNW760
After topping off the overflow bottle with 50/50 water and Volvo coolant, the heat seems to have come back. I’ll update again in a few days just to make sure that was indeed the problem
Old 02-14-2019, 03:20 PM   #13
PNW760
To fully confirm, my heat is now working perfectly. The electric Fan doesn’t kick on either, so it seems that being low on coolant is enough to cause your heat not to work. Thank you everyone for all the help!
Old 02-14-2019, 03:31 PM   #14
Cool. Or should I say, warm?
Old 02-14-2019, 05:51 PM   #15
PNW760
A Parian Hilton “That’s Hot” will do
