IPD taillights 1982 242
I used a set of those 6 panels to replace the original faded/cracked 5 panels in mine. They've worked perfectly for several years now. You know you have to cut the rear sheet metal to allow them to fit, right?
No, I wasn't aware of that. Breaking out the Dremel :whip: lol what part of it needs cutting?
You need to use your original OE circuit board.
No Fog lights 81-84, and it's wired differently.
I have an early passenger side in good shape if you want to keep it original.
If the assemblies are ok except for the circuit board you could wire directly to the sockets. 1/4" spade connectors will fit onto the tabs.
