gottarollwithit
Cooks with motor oil
- Aug 23, 2008
- nut Sac, Cali
Been noodling on how to find a small AC leak. I got a Jeep that i can pull a vac on, but it loses it after about 15 min. It's a pretty slow leak, but some of the AC components are buried under the dash.
What's the fastest and cheapest way of finding this leak??
From what i've seen, pressurizing the system with nitrogen and then spraying with soapy water would be the easiest way to go. Unfortunately, i don't have access to a bottle of nitrogen, nor do i have the fittings to plumb this up. Cost of that stuff would probably exceed what it'd cost to pay a shop.
However, i do have some argon for TIG welding. As an inert gas, i assume that would work equally well? How the heck would i plumb that up to push in 100 psi+?
Alternatively, I have some r134 and dye. Does this method actually work for tiny leaks????
For a big leak, i could envision the dye method working great, but for a pinhole leak, does this take several fill/leak til empty cycles until i can actually see it?
