also - the KNOW DOCUMENTED PROBLEM is probably the best 1st thing to check.
like i said before the holley website discusses this very issue on their website, i've personally dealt with this issue on a car as well, it is a common one.
if the car runs right with no filter, but runs wrong with it, then the problem is with the filter, simple. no retuning, no jetting, nothing but a restriction - again learn how the vacuum secondaries actually work and you will understand why a restrictive filter will cause this problem every time.
OR just go to the holley website and read their documentation CONCERNING THIS PROBLEM
Well that's strange, because I've seen a hella lot of 60-70s cars OEM equipt with Quadra Jets & Holleys with OEM filters. Unless he has a filter sealed up somehow, it's hard to see how the filter could do that.
My Chevelle BBC 396/375 hp had the OEM GM fliter base top & filter, ran like a scalded dog. I had a GM QuadraJet( vacuum operated secondaries), & later a 780cfm dual line Holley, both with OEM filter and filter hsgs.
So what kind of air ilter does this?
QUOTE]
