Old 05-18-2012, 01:03 PM   #1
ingi
Default Looking for base MS settings for my B230FT
Okay, so i got from a guy volvo740 wich orginal was vith b20 and carburetor
and he had started putting b230ft in it an had a Megasquirt1 v2.2 to run it with
he said it had worked but then somthing burned in the megasquirt and he stopped using the car
when i got the car i took the megasquirt out and had it fixed
and now i need some map or msq file who works with ms1 v2.2 to get the car running agine
it is just stock b230ft
with stock injectors
stock turbine
2.5" exhaust
an uses the hall sensor to controle the injectors (lh2.2?)
so if anyone can help my whit some base map or something that would be great
because i have no idea how to program megasquirt
ingi is offline   Reply With Quote
Old 05-18-2012, 02:23 PM   #2
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
http://forums.turbobricks.com/showthread.php?t=257968
you're going to need to get some idea how to program and tun MS. There are going to be settings initial ignition advance, code based outputs, acceleration enrichment, base fuel setting that you're going to need to make based on your setup.
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Black - '98 318i : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 98#/hr injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Driver
Magnum TE is offline   Reply With Quote
Old 05-19-2012, 12:22 AM   #3
propav8r
F*ck Edgar
propav8r's Avatar
Speaking from (little) experience, even if you get a "basic" tune file, it won't make the car run well at all. It may crank, and possibly drive, but you'll be doing a lot of setup yourself. There really is no "one-size-fits-all" tune file.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 05-19-2012, 12:29 AM   #4
Dakar09
The Blue Baastard
Dakar09's Avatar
I'm going to try Tunerstudio Live VEanalyze tomorrow to see how it works. You have to pay for this particular software upgrade, but I'm at the point now where I need some help with the tune, so it's worth a shot.
Tony
1958 Volvo PV444
1983 245 Turbo - The Project - Targa Newfoundland entry - Sold
http://forums.turbobricks.com/showthread.php?t=225396
2002 BMW M5 - Sold
2011 F150 FX4 Screw with Ecoboost V6
Past bricks - '95 855 manual, '98 V70 T5 Manual, '04 V70R 6-speed, '10 XC60 T6
Dakar09 is offline   Reply With Quote
Old 05-19-2012, 03:35 PM   #5
ingi
I know that if i get map i have to optimize it so it fits my car
i'm just looking for something to start with so i don't have to make it from zero
I have been reading the megasquirt manual to see what i need to do and how im going to do it
Old 05-25-2012, 01:19 PM   #6
550
It isn't the map you need, it's everything else.
Does the car run?
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline   Reply With Quote
Old 05-25-2012, 01:21 PM   #7
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
I have found it to not be as good as I was hoping, I'll be playing with it further in the near future though. It will not help you work around problems elsewhere in the tune
Megasquirt Tuning!
Old 05-25-2012, 01:26 PM   #8
550
It works decent for me, but I have only used it for cruising ranges above 2300 or some ****.
Old 05-28-2012, 02:09 PM   #9
Dakar09
The Blue Baastard
Dakar09's Avatar
It doesn't as well as I hoped either. Keeps leaning the car out way too much when left to it's own devices.
Old 05-28-2012, 09:27 PM   #10
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Hey Tony have you tried the heebspeed email tuning option yet?
Old 05-28-2012, 09:48 PM   #11
Magnum TE
Magnum TE's Avatar
I'm spending some time getting the WBO2 delay setup and I think it's getting a little better. I've just been playing with it really.
I payed for the reg key because I use the software so much I felt like I should contribute.
Old 05-28-2012, 09:54 PM   #12
propav8r
F*ck Edgar
propav8r's Avatar
I was also underwhelmed. It seemed to take huge swipes where small adjustments were needed.
Old 05-28-2012, 09:59 PM   #13
Dakar09
The Blue Baastard
Dakar09's Avatar
It really leaned me out drastically. Even with my target AFRs and a fully functional WB going right in front of me, I have no idea why it made the changes it did.
Quite frankly, this entire process is testing my patience tremendously.
Brett..I haven't tried it yet because I can't really get a good log going. Where you ever able to find the VE bin maps for that manifold/injector setup. That would REALLY be a huge help, or at least get me on the road long enough to get a quality datalog together to send to Heebspeed.
Old 06-07-2012, 11:23 PM   #14
linuxman51
linuxman51's Avatar
quality datalogs are not required ;)
just clean inputs and a good wb o2 reading.
Old 06-13-2012, 01:25 PM   #15
Dakar09
The Blue Baastard
Dakar09's Avatar
I'm getting the head rebuilt now, and will follow-up with you once it's back together.
Brett...any chance you found the maps for your manifold and these Deka injectors? An msq file for your old setup may get me a lot closer than starting from scratch. And I'm running out of time to get this thing tuned for our race in Sept.
