- Sep 5, 2006
- San Diego CA
It sounds like it is over tensioned for some reason. The only tensioners I have ever seen break are the URO brand. IF you are snapping the adjuster off an SKF something is very wrong. There are a few of these that I know of that have been using the original tensioner since I came out with this setup. Its the same stock tensioner I have put 100k on with my tdi.
I would suggest looking at your belt tension. perhaps give the belt the twist test instead of going strictly off the tension marks. Usually a belt tracking problem is due to over tension. If you are deforming the plastic and breaking adjusters it all points to too much tension.
I don't make it on tb too much but I stand behind my products. Do not hesitate to call or email with any issue with any of my products.
